Brothers testing it tomorrow and I have a new motor sitting at the parts store if it ends up being that
sent from my truck in a field
I see. Keep us posted.
Brother tested the switch and ran some tests. Encoder motor is getting its 5v reference but only putting out 3v to actuator so its not going, thats why it threw a circuit malfunction code before. He can get one from gm for 179 and will be put in thursday.
Hope it solves your problem! Let me know if you piece it out I'll buy it as a parts truck lol
Sent while drinkin' a cold one...
Got my new u bolts in:
My buddy has my u bolt flip kit plate. Needed the center hole drilled out bigger to fit over the spring center pin. New driveshaft is in the mail and be here thursday. My axle builder said he should have it done by the end of the week which would be awesome!
Installed these today, and came to find out that my drivers side fog light doesn't work. Now I have to figure out why.
Planes are coming in low. Much lower than photo shows
Ryan
Must be an alternate approach. Indy has several runways so maybe winds are dictating a different approach. You can ask Siri what planes are above you if you're curious about their origin.
It's different all the time some days no planes other days fed ex planes are landing on my roof. We are in the flight path of the life flight helicopter that thing flys low. Few wks ago I have no idea why maybe because all the kids were out on the block? He flew in circles above us for about 5 mins then came
Over the trees nose down and took off. Pretty cool stuff
Ryan
One of the coolest things I've seen in recent years was heading on I90 in western Massachusetts. Westover AFB has F15s and they'll show off going over the freeway. Before the Soviet Union broke up there was a lot more activity in the northeast too. NH had F-111s that were part of the SAC so they were always coming and going. When I was real little when we'd be up on Lake Champlain in Vermont the F-16s out of Plattsburgh would go low and fast across the lake. Like a guy with a good arm could knock a ball off the plane low. Loved that. Fighters are probably the coolest thing on the planet.
U bolt flip kit?
F35 is a phenomenal aircraft. Haven't seen one up close but I am sure I will get to since we make the lift system
Ryan
Ryan
Wow strange pic Ryan looks like your grill on your truck is tilted back like a Ford grill.
U bolt flip kit?
It flips the U bolt upside down so it doesn't have extra length from the u bolt hanging down. One less thing to drag or catch when offroading
Ryan
Do you know the history of the JSF program? We aren't talking about the Stealth Fighter or the SR-71.
It was a complete mess, way over time and budget. Chinese hacked the Pentagon, stole the plans, and have what is essentially a Chinese fighter believe to be on par(maybe better since they know our secrets) that was designed, built, and put in the air a good 5 years before the JSF planes were on a comparative scale. When a Telegraph spy photographer somehow got a photo of the Chinese plane taking off for a test flight over 2 years ago, the Pentagon admitted their intelligence said it wasn't going to be flight ready for 3-5 more years. F35 was supposed to be in service years ago, and there is a whole conspiracy movement about Lockheed not getting the bid to build their version.
Its a miracle the plane turned out that good, but then again that is compared to the F16 which is pretty old by technological standards.
Its kinda scary how the US was SO awesome and advanced with the SR71, F15, F16, Stealth planes, and then the next generation there is so much crap going on no one can get the dang things built.
Some bureaucrats decide the money was better spent on server farms to violate civil liberty than get the military the gear it really needs.
Edited by SnakeEyes
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
