Pavement Princess is the way to go, although I tow with mine
Do you have a link? Would definitely be worth it, on my 1990 the bolts were rusted almost through where mud had gathered on top of the plate.
My 88 was the same way when I took the helper spring out. I might have to get a flip kit for my truck too. Sounds like a good thing to have.
Got a closer look looks like just the cv boots are ripped and the ball joints toast so free fix essentially. Just gotta pay my friends back for covering the tow bill. Those guys are the best.
sent from my truck in a field
60% of the truck is clayed, polished, sealed, and waxed. Paint feels brand new again
Ryan
Also tried some new tire dressing from surf city garage
Ryan
No its not, he almost crashed into it yesterday. Within inches :(
I actually put it there to air up his tires.
Edited by RyanbabZ71
Hah. At my first apartment I actually fixed the brakes on one of the kids bikes cause I was worried she might plow into my car. Or get hurt. :lol:
Got my driver's side front axle seal replaced. It was leaking for a year or so. Also found out the vent tube cap was full of sand & mud. Guess that was why it was leaking but oh well. Cheap seal so why not? Plus fresh fluid never hurts. Of course I had to test it so I went through a mild mud hole or two. God I love 4wd.
Lol my jumping days are over
no guts, no glory.. :driving:
GUTS- jumping 60+ tons... :eek:
GLORY- hitting what you aim at.. :thumbs:
My truck is a pavement princess cause it sits on jack stands most of the time lol
If I buy another black one it will be. Years of offloading is just... ugh
Sent from my LG-D800 using Tapatalk
Have an extra bowtie and was at Lowes the other day and picked up some plasti dip blaze orange
Couple more coats and then I'll do a couple coats of the glossifier. Should look sweet
Edited by rdnckhntr94
My other drum came in earlier this week so I decided to put it, and the shoes on the other side. Rear brake job is complete now.
Edited by Daryl Z71
When it's your dd and you make nothing at work you need to make sacrifices.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
