Lol I was always honest still am if i don't know i wont claim to... loved calling him out and proving him wrong lmao
sent from my truck in a field
Radiator is out of the jimmy. Those trans cooler lines are a PITA to remove. Just need to get the clutch fan off now, it's bent all to hell.
Was? You use that like it was past tense :lol:
Ryan
Yeah well I may be a shithead but I'm not so young now. :lol:
Filled it up with gas 2.99 for E85 it's going down again
Ryan
Switched out some seat covers in a Camaro today and boy was this a wild story almost hard to believe.
Took the sunroof out to work on the roof, put crash wrap over the hole, it rained that night and filled the crash wrap and stayed sunny the next two days ( 90+ degrees) and the sun shining through the water in the crash wrap burned the seats and melted the console. Almost like a magnifying glass and the sun.
Don't have any pictures but years ago a buddy had one of the first plug in Brinkman spot lights may have bee 100,000 candle power, one night he had it out and just threw it into the passinger seat and did not notice that he turned it on. Next morning we out to go to work and car would not start, after he got a jump, he saw the light hitting the floor under the seat. There was a round hole in the seat cover and padding, it was a wonder that the car did not catch on fire and burn up it and the house. :jester:
Wow, this was unreal what happened I've never seen anything like it before but one guy said he has seen it before but not to this extent.
If I have a locker in the rear, will that eventually cause uneven tire wear resulting in the shudder feeling I get when I brake (especially 30 mph and below)? I think I narrowed it down to that but now I'm not sure
Sent while cruising down a back road...
Is it a real locker or the G80. Neither should cause a shudder when braking. A real locker may cause tire wear because of how it affects cornering but behind that, no. A shudder while braking is likely warped discs.
+1 for warped discs. Its fine while driving? If you feel something then too it could be a wheel or tire issue.
Remember when I had a caliper locked up on the front while driving my old 90 on The highway. I could tell they had finally
Gone wrong so I kept going to my destination so I wouldn't get stuck. When I got there, the caliper and rotor was so hot it was nearly Translucent red.
Edited by SnakeEyes
That's what I'm talking about. It is a real locker not a g80. I figured it wore the tires unevenly cause the inside tire skips in a turn and over the course of 10k miles I'm sure it did something. It doesn't shake the steering wheel. It's more of a back and forth movement while braking, but up and down if I drive 20 mph (as if there were major cupping in the tires). Weirdest thing. I was gonna put new rotors with new pads last week but I inspected them and they looked fine
And the list goes on:
Before jacking up truck:
While it sits on stands:
Yayyy!!! Bad ball joint! I'll order some quality Moog ones on Friday with my next paycheck. I'll just order all 4 and replace all of them while I'm in there. Clearly Duralast ball joints are not very good. Lasted 30k miles woohooo!!!
Wow, that definitely is a factor in your shuddering problem either I'll bet.
Don't forget to put them in the right way. :P
Not that Im referencing any specific situation in particular.
Edited by SnakeEyes
Haha I know what your talkn about lol
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 679 Guests (See full list)
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
