I hate Rockstars, but im talking about wheel size and lift
I would go as big as 22's probably if I got them for a really good deal
Sent while cruising down a back road...
Then 22x14s. Don't wuss out man
Sent from my LG-D800 using Tapatalk
would have to be a really good deal. that's ALOT of wheel right there. It would probably rub somewhere haha
Edited by rdnckhntr94
I got full faith that you will rock it correctly
#robbedpower
#atleasticanlookinmywheelsandseeifigotshitinmyteef
lol
Come on Webster you should know how to spell teeth :lol:
Ryan
thought about washing it today, but glad i didnt as i looks like it is going to rain and will all the cotton flying around from the cottonwoods it would have just been an exercise in futility.
I hear you there. My truck is filthy outside but it's the daily rains of June in Georgia so I figure why bother. I really should get the undercarriage cleaned up as that's the worst and rain don't do much for under there.
#toomuchhashtagneedabullet
#oldfogey
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
