Yes drove it put it on stands pb blaster on the bolts and cranked it just kinda twisted off... bad bolt
The torsion key adjustment bolt broke? That's crazy, never heard of that happening!
Sent while in 'Murica...
I adopted a new dog on Saturday. I thought I had everything for Pip...she came with the name...but as soon as I got home I realized I had a 36" long dog and a 24" long kennel...
So yesterday I went back out to get a proper size kennel. She is a hound mix. I haven't been able to get a clear pic of her yet, 11 months old so she doesn't sit still for very long.
No problems with her in the truck, it was getting her back out was a chore.
not today but on staurday drove a few hours to look at a few gmt 800 tahoes. First one was an 06, but was really dirty compared to pics and on the test drive the low oil pressure warning came on, yeah didnt by that one. Drove an 03 with 110,000 on it and it was very good, cleanest interior i have seen yet and just a few issues. minor bumper ding and a cracked mirror housing. Decided we really like it and bought it. Will have to start a build thread on it.
Happens all the time on northern trucks
I would guess so with how heavily they salt the roads
Edited by rdnckhntr94
Gassed it up and drove in some snow
Ryan
Don't you mean corned it up?
How much of a mileage hit do you take in the winter on the corn juice? Is it like winter blend gas?
I may burn a tank of that stuff over the winter, maybe. Just not sure about it, even though I'm surrounded by corn and soy beans.
I loose about 1/2 mpg. If I drive around in 4wd I loose about 1 mpg. Normally around 10-11 drops to 9-10
Ryan
Was towing with my "performance" transmission that I installed 12k miles or so ago and found out 2nd gear is slipping. How does a trans rated for double the trucks hp go out so soon? Yes I run 35's but I also have 4.88's so that relieves some pressure on it
Pulled code P1870. Sounds like a valve body issue. Not too bad but still puts me in a bad mood
You put 12k on that faster than I put 12K on all my vehicles combined. Sorry to hear that its crapping out
F road salt
Ryan
Looks like it got you first.
Hopefully it is just a valve body and hopefully they will cover it if I take it to a dealer and such. I'll talk to him later on luckily they have good customer service and long hours. And dang that's crazy, but sometimes I use it for work (like I was today)
Ryan
Ouch, maybe I won't. The worst tank MPG I have had to date so far in my truck is 17 MPG. That was last winter when I was out playing in the snow, remote starts to warm it up, in the coldest part of the winter.
I agree with you on your salt post. We get at least 6 months of that per year up here in MI. MI puts on more salt per lane mile than any other state in the nation, by a large margin. My car doesn't come out until Memorial Day weekend, and is usually back in storage the week after Labor Day. So 3-4 months is all for it.
E85 isn't worth is currently around me, the price differential isn't enough. That and winter blend E85 has lower ethanol content so you don't get as much of a performance gain either.
Well I can't figure out how to upload a video via tapatalk but I got a video of it slipping. Trans temp was around 110 (approx. 90 degrees above ambient) and I also found out that it's not just second, but third is starting to slip as well. Of course, it's only my luck that it would happen to lol [emoji23]
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
