GM needs a white pearl like ford... Not white diamond that looks cream colored
They need one like Lexus/Toyota and Nissan, sprayed a Lexus pearl while the other day that is almost bright white but it dances with pearl when then sun hits it, paint code was 077.
Did a 5 min spray off looks a ton better. Tonight ice so more salt tomorrow :(
Ryan
Hey Ryan, where do you wash your truck? Garage, driveway, etc? Reason I ask is my last truck last winter I just ran it to a touchless carwash and called it good but with the new black truck I would like to wash it myself but I am worried about all the water and the cold weather.
In the winter I spray it off at the coin op place ($2.50 for 5 mins). I then wash it in the garage (2 buckets rinseless wash normally). I squeegee any excess water out of the garage
Ryan
Spent 3.75 spraying the snow ice and salt out of it.. truck had so much snow packed in the front end it was horrible 455954d18ced2c33627aa59dad0a027b.jpg
Tow mirrors make a lifted truck look so much better.
HMMM looking at the photo with the tow mirrors and snow
Put a pair of skis on and hold onto the mirrors, would be a fun ride :)
Had to put the 14 in a ditch after some guy decides to stand on his brakes. It was slick out and my truck slid, his didnt. Made a last minute maneuver into the ditch, which luckily wasn't deep or really muddy. Just gave it some gas and kept going. She pulled out in 2wd. Got home and only damage is mud on the tires. Thank goodness!
Sent while in 'Murica...
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 557 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
