After letting the pb blaster sit over night on the bolts for the intermediate steering shaft, nothing budged still. Ugh so annoying, not sure what to do now. On top of that the cable for the fold down single side seat broke so now I gotta replace that. [emoji20]
Edited by cobrajet84
Went shooting at the riverbar and did some serious off offroading on accident. My approach angles are not that good.
Pretty good! I can get close to that on city miles if I try hard enough. Never got above 14 on the highway though. I think your truck is almost identical to mine.
Edited by sahls01gmc
Got gas last night, 12.7mpg on the last tank full. Not too shabby for a 6.0 and a ton of miles driving around town.
Go to 3.42's and all city driving. You can get 13.8
Go to 3.73's and you can get 11mpg city! lol
15mpg average with mixed spirited city/highway. I think I can get upper teens all highway.
6.0 and 3.42's i get about 13.8 all in town and 18-19 on straight highway driving. As soon as I have a load of any kind, highway drops to 15ish. With my future plans I can't use a 4.10. Smaller tires and blower will cause major traction issues
Edited by Chris
If you put the right tire on, you should be able to hook when you need to.
Blown 6.0 with 3.73 and a 30" 285/35/22 would be a great combo. May go to 3.90.
Goal is to be at the top of 3rd gear when i hit the trap
Edited by Chris
I am just barely drawing up the plans. I need to lower and do the tires first. Then get a baseline with the 3.42 before i start with engine work. I will be using a fairly sticky tire and a roll control system.
Smaller diameter tire will do the same as a lower gear. I will be doing both
22 inch wheel probably wont give you the sidewall needed to really hook hard. Not to mention they will likely weigh a good amount. What blower you looking at? Planning to do a 4l80 swap?
I will probably run a 17" with drag radial at the track. To stay legal it will be a MP112 most likely with meth. And unfortunately i will be doing the 80e swap. It isnt cheap and it is time consuming. But in the end i figure the engine will be somewhere around 500+ HP. The current 60e will probably only take 3 launches beforw it scatters down the road.
    1981dustin
    1981dustin
  • Who's Online   3 Members, 0 Anonymous, 1,572 Guests (See full list)
