I went to the local golf cart shop last night to get new head light bulbs for the golf cart. Then this morning I took the truck over to the car wash on base and spent about 15 minutes blasting as much dirt and mud out from the undercarriage. Still plenty left in there but the 6" deep pile of much is showing some progress.
Grandma had an old door without the safety sensors, and years back I hit the remote to open it as I pulled in and she happened to have already opened it to back out. She ended up with a nickel sized dent in the roof of her Civic. She wasn't too happy with me for a bit.
I taped the safety sensors together, facing each other, and placed them on top of the motor on the side with the new door. Hate those damn things. I installed the opener back in '03 when we moved in. Tried and tried to defeat those sensors, but that company sure doesn't want you to do that.
I have to hit the button in the truck, then walk out the closing door ... otherwise I have to dig through my pile of keys to lock the 2 locks on the side door. In the summer, the door and jambs swell, making that task a pain in the ass. Much easier to just lock the door from inside, then escape while the door is closing. Stupid sensors wouldn't let me do that. Apparently lawyers have had their way with garage door opener manufacturers ...
The other door's opener is a 30+ year old Alistair unit. Chain driven & indestructible. Not a safety device to be found on that one. :)
New garage door. It is real nice. Very smooth and quiet unlike the old one. Kinda glad I took it out
Ryan
Wow that door is HUGE! Must've been a 2-man job I bet. Looks great though.
Happy Thanksgiving everyone. :cheers:
I think led bulbs from a quality bulb marker, in stock taillights would be much more reliable.
My stock tail lights are trashed
Sent from my SM-G925V using Tapatalk
Standard 16x7. Two guys did put it in
Ryan
Really now? Lolololol [emoji23] [emoji23] [emoji23]
Used the truck to rent a stump grinder to grind one stump at my house and four at my parents. Made a rainy crappy day into a very productive one.
That's something I haven't used in a long time. My joy-riding days are over, so I don't need one as much as I used to. Had a 2 page driving record back in the day ... WITH a detector! I can only imagine what it would've been like without it. Probably 3x as much. Thing paid for itself 100x over.
I was one of the only guys to have one on a motorcycle back then too. I used that industrial velcro and stuck it right on the tank. Can see it in the pic - the thing is huge by today's standards. Any time I parked it, I could tear it off and carry it with me. I still have this one in my stash of junk somewhere ... and it STILL works! Made an ear-piercing shriek that you could hear plain as day at any speed, helmet and all. When I sold the bike, the sticky-tape on the velcro peeled right off with a fingernail.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
