The wife and I used the Silverado to go pick up a new member of the family. Local Animal Services was waiving the adoption fee for dogs 45 pounds or more. We saw quite a few but one really stuck out and we both knew he was the one going home with us.
This is 1 year old Bentley
  • Like 5
Rode in dad's 2013 duramax 3500 SRW with 250,000 miles on it. Rides pretty good since he added the Rancho steering stabilizer I bought him.
Glad I could provide some laughs
Ryan
Very grateful glad I keep you around
Sent from my SM-G925V using Tapatalk
Edited by SarahsGMC
Took apart the passenger rear door. Had one hell of a time getting it unlatched at the bottom. The latch was completely locked up on this side compared to the drivers side. Ordered another latch, and added sound deadner to this door too.
Just bought a 2014 Sierra 2500 HD. Added on to my insurance and choked and stammered a little. Collected myself and drove home.
What kind of sound deadener is that? Kinda looks similar to the 3M undercoating I put on the rockers of my truck recently.
Nevermind, I see the sound deadener. What kind of spray did you use around the latch? That's what I'm curious of...
Edited by sahls01gmc
After the last rain storm that tore my road up so bad I think I broke something on the truck. I'm getting a new clunking noise while driving, doesn't do it over bumps so I don't think it's ball joints, I'm thinking it's my sway bar end links, the bushings are shot too so I'll probably replace them all so I know there all good.
I used the same paint around the latch that I used on my frame which is Chassis Saver. Then the next day I sprayed over that with flat black spray paint. Can't wait to move out of this freaking rust belt state, maybe I'll be able to make my truck survive then.
Thanks guys I'll get a lit up pic later I forgot to do that lol 4f369c949abb4315930701de8b5dfcd3.jpg
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,228 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
