Frankly, I'd leave the antenna on. If the antenna is hitting you know the roof isn't far behind, and with a lifted pickup that could definitely be a concern.
Sent from my SM-G920V using Tapatalk
Hung at a Stealership.
Could you have a worn out pully or tensionor?
Wouldn't hurt to run a tape measure from roof to ground, and sear that number into your brain. Definitely a good number to know!
I had just a stock '94 K1500 that someone had cranked up the torsion bars on. Went to this hole-in-the-wall carwash after work - noticed the clearance was looking pretty close. I asked the guy, " Am I gonna make it here or what?" He says, " Sure - plenty of room." OK! So in I go ............. BAM!! SCREEEEEEEEEEEEECH! The metal spindles for the spinning brushes slammed down on my roof, dragged a pair of 4" wide gouges parallel to each other, then, formed opposing lower-case "h" patterns as the brushes moved away from each other. Destroyed my roof. Lucky for me, the guy shared a building with a body shop - 100% paid for, fixed right, and no insurance involved. Worked out good ... but LESSON LEARNED!
Those were changed with belt four months ago.
Just ran over a dead deer going 70 mph heading to South Carolina messed up the little rear mud flap it front of the rear tire hit it dead on the front driver side thank god ive a little lift level
Yikes - glad that's all that happened!
I just finally found the source of the non-stop rattling over bumps that was coming from the rear of the truck. Sounded like I had a bed full to the top of brake rotors, and every time I hit bumps, CLANG BANG ... drove me nuts for a year and a half. After going down a chuckholed dirt road today, I said THAT'S IT - fixing this TODAY.
Turns out, the upper mount for my airbags was totally loose, and slamming into the frame. When the truck sits, you can't move anything - all feels solid. But, if you jack the truck by the frame, and let the axle hang halfway so the bags are totally unloaded, the play was obvious.
Amazing how much that SOB rusted in 1.5 years. Covered in used motor oil & Fluid Film too. Thought I was going to bust the bolt off in the frame. Got it out thankfully. Wire wheeled the hell out of the bolt, threw medium Loctite on it, ran it in, then slathered the top of the threads sticking out in the frame with anti-seize. Hopefully I won't have to remove them again .. but that should make things a little easier.
Debating whether or not to throw my summer wheels on or not. Been hearing rumors of snow again though ... :mad:
http://vid297.photobucket.com/albums/mm215/jjs05polaris/Forum%20pics/0409161357_zpsdltwhddn.mp4
^^ That sounds like my hitch bouncing around on the butt of my truck. I need to find some shims or something to shove in there to quiet it down a little bit.
Yeah that's exactly what it sounded like going down the road, only about 10x louder - I could feel it in the floor, too. Can't believe I put up with that for 6k miles ...
Got my other headlight bulb changed
This side more of a PITA still easier than my brothers Malibu
Ryan
How about a "Beat A GM Engineer For Charity" day? :lol:
i put a small lift kit on a 2010 jeep
Edited by SarahsGMC
I took advantage of my parents driveway today and washed out the bed, wheel wells, and engine bay. And with my luck I ruined the cloth hood liner while trying to clean it, the fuel from the other day made it look horrible but I should have left it how it was.
Used my 13 Chevy 5.3 to pull my 13 000lb apartment on wheels to the shop so I could was it and detail it as unfortunately Im selling my 5th wheel trailer dam nice unit hate to see it go but it's times. Gota sell it now while it's still worth a bit and now that I moved into town I don't really have a place to park it. Iv bin living in that trailer full-time for almost two years including the -50C winters over in Alberta with no problems also had my nabour witch wasn't doing nothing for Christmas over and I cooked a turkey and had all the fixings pluss few gallons of rum.
I've been trying to sell my parent's '04 Sunnybrook for over a month now. No bites. Guess they're asking too much.
EDIT: Had the wrong name, lol - was thinking of the one they had 13 years ago ...
Edited by Jsdirt
Get a few thick old non-needed bold washers to use. (Stainless Steel) Worked great for my loose hitch.
Doesn't mean that you didn't get a bad one. Maybe re-check em again?
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
