Took me a while to figure out that was a pad in the first pic, lol - I always forget the rest of you have discs out back. :lol:
I'm doing e-brake shoes on a '98 Toyota Camry today. So far, I've got one stripped caliper bracket bolt on one side, and one busted caliper bracket bolt on the other. The shoes were a ROYAL PITA! Needed 5 hands to hold all the different pieces behind the hub to reassemble. It's non-removable ... until you remove the shoes, WTF.
Even Toyota sucks today!! What a dumb design.
Edited by Jsdirt
I should've taken a pic of this Toyota. I had a MOUNTAIN of friction material an inch deep on the driveway when I was done. :lol:
I'll get pics of the destroyed shoes later.
Edited by Jsdirt
Got EBC solid rotors & Yellows on the front of mine - 30k HARD miles so far. Starting to get thin now.
Only thing that sucks is the brake dust, but they work just as good as OEM.
I had to run around to get things to put the stereo in the F150. My Sierra started overheating at a light.
Here is the finished radio
Looks like it fits good.
Ryan, you'll throw those POS EBC's in the trash in less than 10k.
Sent from my SM-G920V using Tapatalk
We will see
Ryan
Here's the pic I promised. Guy didn't leave the e-brake on - everything rotted and seized solid, so it was exactly like leaving it on. He's been driving it like this for 3 months, as you can see, lol. The other side puked a mount rod, and all it's hardware. Found the spring trapped inside - everything else, gonzo. Wish I had a pic of the 6 month old rotor on the bad side. E-brake drum was trashed.
This was after taking my backpack blower to the whole thing, and the driveway:
Struts aren't even a year old - already rusted, and weeping oil. They actually look 10x better in this pic. Advance Auto quality for ya ...
Almost forgot to include this pic of some "quality" modern engineering. Lets coat HALF the brake line with quality nylon ... but then just go back to basic steel for the rest of it. FANTASTIC idea fellas! :thumbs:
FoMoCo, btw:
Edited by Jsdirt
We will see
Ryan
My main issue with them was the dust. Had to clean wheels multiple times per tank of fuel, and I'm by no means heavy on the brakes. Poor wear too.
I never get more than 30k out of tires and brakes anyway. The brake dust I can do without, but I like being able to stop fast whether the truck is solo, or pulling 8k. They work pretty damn good.
If I can find something that stops as good or better with no dust, I'll be all over it. Haven't really researched that yet.
Which series they have two green stuff series.
Ryan
Previous 2000 Silverado had two rear brake changes (one under warranty) before 50k miles. These lasted 64,885
Ryan
My buddy had a '99 Silverado 1500. I think he was on his 7th or 8th rear brake overhaul in 100k miles, when the parking pawl in the transmission let go (because the e-brake never worked right). He didn't keep the truck much longer after that. Was starting to have multiple issues.
Edited by Jsdirt
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
