Got gas Saturday morning and had the 5 gallon can slide on the tailgate and start spilling as I was trying to put it back in the bed. That factory spray liner is stiff and slippery on a cold day. Thankfully I wasn't too far from home and cleaned the truck up afterward. :fume:
Gm liner? Did you have line x prior?
Cross drilled rotors look cool but not in a road salt environment. They will start to rust and swell around the holes and become very noisy. Unless they are Stainless. Drilling also makes them susceptible to cracking.
Yea I don't prefer them, but they are the only rotors I've been able to keep on my Cruze without them warping/shaking.
Yeah, it's crazy. Seems like everything across the board is just going up, and up, and up ... :nonod:
Definitely would be nice to be able to reload rimfire rounds. Could sit there and make thousands of them.
I bought a Rock Crusher a while back - still haven't used it for the Marlin ammo yet. I think I bought everything I needed, and then got sidetracked with some tough jobs - haven't looked at the stuff in 4 years!
I've also got a Hornady Lock N Load progressive press, with a case feeder. I can crank out pistol rounds with that like crazy. Think I hit close to 500 rounds an hour doing .45 ACP. Can really get it moving once you get a rhythm going. If I had a way to automatically keep the primer tube full, I'd be able to go even faster.
I haven't used it in a while. My wife hoards quilting supplies - it's buried right now ... :noway:
Just realized my cat Buddy is in the background there. RIP - miss the little guy. Best cat I've ever been around in my life. Was like half human, half dog. He weighed 21 lbs. when this pic was taken.
Press%20Hornady%20Lock%20n%20Load%20guns
Check out my post in the guns section.
Sent from my SM-G920V using Tapatalk
The trick there is to properly torque your wheel lug nuts to equal 100-110 ft-lb
Have done that all the time. Damn car eats brakes like there's no tomorrow, probably because the rear drums seem to do nothing. Put the slotted/drilled rotors on with semi-metallic pads and haven't had a problem yet. Been over 20k miles now. Even went from 16" to 18" rims in that time frame. I only got around 12k miles out of the stock brakes before they shook the hell out of the car.
Edited by Daryl Z71
I just repaired and other set of 2009 Cobalt FOBs ( 22733524 ) for this man's daughter and one for his wife's 2007 G6 ( 15252034 ).
I had a Permatech on the last 2. It seemed a bit more cushiony and less abrasive when crawling on it.
Watched my windshield crack
Dealt with a little snow
Ryan B.
Got my Denali plastic bumper ordered. Need to order the side braces now and all the plastic body work for it
I can't get those links to work, Ryan.
They also chew through your pads faster. I've stayed with solid rotors with EBC Yellows - thing stops pretty damn good for a 6k lb. truck.
I've got OEM GM shoes & drums in the rear, 2nd set in 88k miles. They're wearing a little funny though. The leading shoe is really thin, and the trailing shoe still hasn't worn in enough to use 100% of the friction surface. It's at about 75% now.
Edited by Jsdirt
I just did drilled and slotted rotors on my wifes van we will se how they hold up as we just started the snow/salt season here
Side braces ordered. Now I need the grille and all the plastic shit up front if anyone wants to get me a "Non-Denominational Holiday" present
