First impression driving a decent distance with the balancing beads is good. While the tires seemed really smooth without any balancing, they're even smoother now. For $30, I'm very pleased. I doubt I'll ever have tires conventionally balanced again. I guess there is a reason so many commercial users buy them.
Sent from my SM-G920V using Tapatalk
Aren't they supposed to help extend the life of the tires too? Because every time you drive they rebalance the tire?
Sent from my SM-N920V using Tapatalk
minus the cracked dash :(
Mine is an eleven, do you have a picture of where it cracked?
3 places on pass side.showed up a few yrs after a Labor Day weekend trip out of the blue. This is the worst
Ryan B.
I have a post on here somewhere that I made a few years back with pictures of the areas prone to cracking...I looked at 15 different used Chevy/GMC trucks/SUVs on the used car lots around here one night. Of the 15, there were 12 that had the cracks all in the same place. The cracks appear at the corners of the dash surrounding the passenger airbag
Not my picture but you can see where they occur here (corner closest to the center of the dash and the corner closest to the A-pillar
http://www.gm-trucks.com/forums/topic/152570-cracked-dash-2008-silverado-ltz-cc-vmax/?p=1559141
Edited by hammerhead611
Yes. I had them on my sportbike back a few years ago. Never had a problem on it, and I would frequent 100+mph and hit 156mph one and felt comfortable...until a wind gust came and made me realize I was stupid haha. I haven't used them on my truck, but I might when I replace the stock rubber.
That's the idea. They're just ceramic beads that roll around in the tire. I've decided conventional tire balancing is pointless since the tires generally wear enough in 10,000 miles (or less) that the balancing is off.
I didn't plan it this way, but I essentially got a control test without any balancing. I was surprised how smooth it was with none. But the beads did make a positive difference.
Yeah I hear those things work pretty good. They were always used in truck tires when I was driving TT and straight jobs. The guys there told me they had been running those beads for years.
I figure if they can balance a tire that weighs 100 lbs. + , they should have no problem doing anything smaller. :)
Edited by Jsdirt
Anybody on here have the pinout for a 2005 Mustang GT Instrument Panel. I don't normally work on these clusters but I have a 10 thump buddy who insist I repair his Mustang cluster. Please help, he can be so annoying!!!
now you need a case :)
Edited by RyanbabZ71
The case is overpriced. Want a case, go buy a small Pelican
I did a stepper motor on a '05 V6 Mustang. No pinout though - was just cave-man work, lucky for me. :lol:
Edited by Jsdirt
What is that?
Yea I would like to have one, $50 is pretty salty though.
What is that?
I know you have prime so free shipping
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
