An other Youtube subscriber that went the ebay way. When will they ever learn!!!! This really hurts me when I see this type of carnage.
He was wondering why his speedometer wasn't working, look at one of the pins that never made it through the board, it just curled up and never made it through the hole for the pin.
Made it work, my June miracle, can't perform anymore till July.
Edited by Coby7
Nice soldering job they did there. :lol:
They still injecting nylon to retain those at the factory?
Yes
Ahh, gotta get them hot then. This is a fantastic design with an aluminum driveshaft ... :nonod: Not looking forward to doing mine when that day comes.
Front shaft is steel with plastic retainers on 2500, rear shaft is aluminum with outer clips
Edited by Chevor
AHH, yeah, you said FRONT. Don't mind me - braindead ... lol. I recall seeing clips on the rear of mine as well, so I'm just wrong all the way around tonight! :happysad:
Edited by Jsdirt
Yesterday my buddy and I did front brakes on a dodge caravan. Then the sky decided to open up right as we were dropping my transmission pan. We changed the external filter, internal changed to a deep pan filter, and installed a deep pan filter. Supposed to add an additional 3 quarts of fluid to the system. So far I've put in a little over 3 gallons of fresh transmission fluid. Such a pain to find Mobil delvac 1 ATF. None of the parts stores have it, only NAPA said they could get it. $43.75 a gallon. Some sellers on amazon are selling it $70+ before shipping.
Today drove my truck to the dealership to return the coolant that I ended up not even using. Also checked on what the torque spec is for the rear diff drain plug. 24 lb/ft, same for the fill plug too. Neither one were anywhere close. Pretty sure the transmission plug wasn't anywhere close to whatever it was supposed to be. $400+ later in parts and fluids I'm good for another couple months.
Nice!
I've been waiting for the weather to cooperate over here - finally a peak of sunshine for the first time in a week.
Got to get started on the Nightmare Tahoe - that was the one I had here for over a year trying to figure out why it would only run on 6 cylinders, no matter what we did. That vehicle was the motivation I needed to learn OBD-II inside and out. Anyway, long story short, it ended up being exactly what I suspected - the local junkyard ripped me off. Told me the computer they sold me was out of a V8 Tahoe when the VIN came back to a '96 S10 Blazer that was in a wreck! At the time I didn't have my Autel scan tool, so I couldn't prove it - the guy saw the doubt on my face and took advantage of me. Told me he'd only honor the warranty if I had a dealer troubleshoot the entire system! Wish I knew then what I know now ... or maybe not, because I probably would've socked the guy in the mouth ...
ANYWAY ... the Tahoe is here for exhaust work, tranny seals (shift shaft and tail shaft), and a pair of inner / outer tie-rod ends, plus sleeves. Then I have to get it aligned, and get a sticker for her.
Yeah as far as drain plugs go, snug is all they should be. By hand until they touch the pan, then maybe a 1/16th turn after that, or less. I've never put a torque wrench on one. Some people get paranoid and hog down on the things ... so the next guy rounds the thing off ... & I get to extract it. :lol:
Edited by Jsdirt
To the dealer to get the right front seat replaced. Seat back adjustment motor froze with seat back all the way forward.
Wow, that's insane! I've got a 24 year old Volvo, and a 31 year old Ford with power seats - both STILL function perfectly ... although the Volvo has a bunch of grit in the works. Can hear it crunching as you move the seat fore and aft.
They just don't build stuff like they used to, and that makes me angry. :nonod:
Yeah it rained off and on the 2 days we were working on our trucks. I was on the gutter side so I was laying in a mini river yesterday. Nothing like ATF and run off water to condition the hair and skin. :)
I had the lumbar motor replaced on my driver's seat a couple months ago. Unfortunately for some reason the extended warranty didn't cover the bottom rear seat motor so now the bottom back of my seat doesn't move up and down. Front can still be angled.
It was a big week for my 2006 so far. I pulled out another pickup at the lake Monday and rolled over 150,000 miles this nothing.
Sent from my SM-G920V using Tapatalk
I hit 176000 on the 2007 coming back from dropping off the 2017.
    • How many miles were on the truck when you bought it and was there some form of oil change history generated through a dealer or an independent shop although not much would show up if the owner had changed their own oil. Just curious if it was a maintenance issue or if there was something off from the start, surely one would think the original owner would have realized it was using a lot of oil, its hard to go back in time and find out the true story of mysteries like this. Well hopefully the warranty company will go for it and just install a new engine, that would be the ideal outcome.    I still have so few miles on my truck as per not quite 9000 and will be changing the oil shortly which has around 2700 miles on it or so and its down so little on the dipstick from where it was at the beginning of this oil change that I could make the "claim" that it uses no oil but in reality would be a very small amount, less than a 1/16 of an inch. Just driving empty/not towing and easy driving so hard to say what it would do if it had a load behind it for oil consumption. So far very impressed with the very minimal oil usage.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
