went to the truck/tractor pulls, saw some awesome trucks and it was mostly chevies only 2 fords and some dodges 2 gmcs TORE it up
You been to the dunes recently? I just read that some sort of plane/glider crashed on test hill yesterday.
Drove it to town and got some DEF now just got to add it!! :jester:
Drove to the other side of town to the new Sunoco station, found out they have 93 octane w/o the ethanol in it. My truck is a happy truck now. And all my lawn equipment and my John Deere are going to be happy as well...
apparently it was a husband and wife parasailing they crashed into test hill and both lost their lives, they own the parasailing place out here in shelby.
Edited by SarahsGMC
Prepped and cleaned truck for thunderstorm tomorrow LOL.
In the off chance it doesn't happen then to a car show!
Wow, that is very sad. May they both rest in peace.
went to the fair for the demo derbies, real sad that i didnt get to race and that everyone kept coming up to me asking why i wasnt in the races.. ill be back in next year..
then went out with the boyfriend and the cops were CRAZY we went two tracking then when i took him back to his truck we JUST stopped and a sheriff came flying into the parking lot and shined his light on us wanted to know what we're doing he checked our IDS accused him of being drunk when he wasnt and then let us go.. but waited there until we both pulled out.. then we went downtown and got pulled over again after just passing 3 other cops and a different one pulled me over while he was with me and said he couldnt see my tail lights.. there had to of been like 10 cops cruising around it was nuts!
At first I did this
Then I did this
Followed by this
Finally I wanted to do this
That's cool Brad I really value your opinion let me put it with the rest of the things I don't give a f*** about ;)
Took my neighbor to look at trucks.........
He ended up with a new 2013 Silverado LTZ crew cab with EVERYTHING. Z71 appearance package, deep ruby metallic, GM wheel well liners, GM side steps. GM bed liner, GM tenneau cover, exhaust tip, GM deluxe floor mats. Hello GM, bye bye Ram (gave it to his son)! He loves the Silverado.
Only cost him $40,488
Edited by BlackZ71Silverado
Sent from my ADR6400L using Tapatalk 2
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
