Yea I have some custom painted caps, bow tie is outlined in ashen gray
Ryan
Here you can see my truck in the bumper :)
Chris I also did a close up if the caps
Ryan
Yea few hours after I swapped them out. Someone I knew who was looking to have a spare set
Ryan
Took a buddy of mine to buy his first GM Truck! He Ended up with a 2010 Silverado Ext Cab with the 6.2Lwith 32K miles that I found.
Good timing for Christmas.
Yea basically got half my $ back that I spent on new rims.
Today I washed my truck. Went to the local car wash sprayed it down then drive home and did a rinseless wash. Real fun when the temp is 20 degrees :( Truck once again looks nice. Been filthy with all the snow we have gotten
Got a woody today an some other duck, 45 minute drive each way but it was worth it to see my boy retrieve him !
Sent from my smartass iPhone using Tapatalk
Washed my truck for the first time in 3+ months and that's what happens to me. I scratched my wheel. Guess that means these are my winter wheels and I can get my 20's and 37's now lol
Sent from the side of the road...
TPMS system died. Takes 3 minutes for horn to honk for first tire. Times out before I can do all four. Discount tire, see you friday
Edited by SnakeEyes 325is
Drove to grandmas and parked on a big snowbank in her subdivision lmao 70 miles round trip. plowed through two feet of snow in my yard without getting stuck it was funny.
Sent from the toilet
Sold my hydroboost booster and brake pedal today
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
