Damn its even got an LBZ, slick looking truck. Be better with a solid front axle
yea it, that thing was so sick! It actually had a BDS lift kit on it, no solid axle
did the 32" mod, joined the 32" dump club, and no change to my exhaust sound.........oh well.......
Well it was actually a month ago now, but I finally got some new tires on the truck. This time I went with Firestone Destination LE2's. The previous AT's were great but I've calmed down a bit so I went with something a little more appropriate for the roads I drive on. So far I've got 2k miles on them and they are really quiet and wearing great...now that my alignment has been done again.
Weather permitting I've got to readjust my front left fender tomorrow. Somehow that deer I hit knocked it forward and it's causing some bad rubbing.
I will probably be picking up my AFE intake and exhaust on Monday. Hope to have it installed over the Christmas break. Also ordered my Rough Country Leveling Kit. Hopefully it'll arrive before the end of the year. Hopefully I can order my wheels in February when Ray's releases them (no more 5 step forging on the TE37X. Going to a 3 step forging on the new TE37X Ultra).
Got my tires rotated and saw this sweet dmax on 40s thereeqarugar.jpga2abuze3.jpgy9y5a3y8.jpg
Sent from my smartass iPhone using Tapatalk
needs an alignment badly
Tomorrow hauling my new camaro rims to the shop to have tires mounted :)
Ryan
Took my truck vehicle shopping for the wife, she ended up getting a new Equinox LTZ. Will be here Tuesday.
They are factory reproduction ZL1/1LE rims. 20x9 fronts and 20x10 rears. Much cheaper than the gm version but look the same :)
Ryan
Edited by RyanbabZ71
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
