Got new emblems.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Removed the after market rear sway bar last night. Wish I had done it sooner. Didn't realize how much it made the truck understeer. Also the bushings in the end links were pretty warn and rattled quite a bit. If I ever get a camper, which is doubtful, I will put it back on, but I like it better without it.
took 3 of my boys out two trackin in my truck, had a great time hitting some interesting trails, very very good time and lots of laughs
What is two tracking? And I got my Vortec Max emblems in today. I want to see if I like them on it, but Its been raining.
I put the Vortec Max emblems on to see how I liked them. First impression I like them. My brothers and my fiend jason do as well. But it could wear off. I also decided on what new wheels I'll be getting.
By the way this limit on tapatalk uploads is now being a royal pain in the ass.
Edited by chawkins6789
No it was dyno tuned by Cal Speed and Performance. I'm going to have Black Bear Performance do a couple extra tune like for towing and economy. Getting 12 MPG. But I haven't spent more than 40 miles on the freeway this week
12 mpg ain't to bad man. I wouldn't complain. Especially mixed driving like that.
agreed.i havent seen 6.0's getting too much more then 12.
Picked up a new gun. Pics after lunch and after I get it all pretty. :lol:
Chris, the badges look great. The mpg is about what I got with my '07 and about 3 better mpg than my '02. Have you thought about clearing your headlights? You already have the markers in place. In your new pic it would make that VORTECMAX pop even more. Did you click "buy now" on those wheels? Nice.
Mike, maybe with pics of you new gun, your fellow "duners" will quit giving you a hard time about some past incident involving you, your truck and some sand...?
You have more courage than I do Sarah. I love the look, on your truck and those like mine, but I know I'll end up screwing it up and have foggy headlights...
I probably will and if I do then I'm buying some I almost 100% sure they will go bad like everything else I do
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
