So at night they aren't on unless using the brakes?
Correct. I remotely started my truck this morning, as I was leaving the hangar, hitch light flashed and remained off. Don't know why I thought it stayed on.
This morning I started cutting a 2x12x96, for storage management in the bed. Cut it to 64.5", leaving the line, fit perfectly. Started painting it, and had to put it on hold while the one side dried and I had to go "rescue" my kids, TPMS light was on in our CR-V. Will be time to go to bed soon, working the "graveyard shift."
Think I'll plug the holes in the rear wheel-wells, after I get home and before I go to bed.
Finally got around to removing the cheap LED fender marker lights I put in that have been flickering for a couple weeks. Went back to the old filament T10 bulbs I had in a drawer until I find decent LEDs and start replacing all my bulbs.
The Philips LED bulbs I put in the license plate sockets didn't even make it 6 months. Screw LED, going back to the regular ones.
My led issue is with camera washout. But mine are sylvania. They work great though
The LED "pods" I put as auxiliary/backup lights fortunately don't do that, not enough to bother me at least. Maybe it's because they are under the bumper instead of the reverse bulbs being switched out.
Edited by Chevyguy85
I do have LED reverse bulbs in and so far both are working well after a year, just a bit of flickering when it is very cold, under 20 degrees.
Wait, so you are driving with a trailer at night without taillights? That sounds like a lawsuit waiting to happen.
Finally washed/cleaned her this weekend after being gross for about a month. A typical windy and dusty spring hasnt helped, nor the construction site next door at work.
Sent from my SM-G550T using Tapatalk
Where the HELL did you get trailer out of this? TOW HITCH BRAKE LIGHT!!!!!!
Calm down now, I thought trailer too at first. Had to re-read it to understand
Sent from my SM-N920V using Tapatalk
Getting sr-a's rotated balanced for most likely last time after
22k miles.
Finished up polishing my wheels.42138bfca513548b637a19f1f7793202.jpg6bca4ce4e58219e4b7071e986992031f.jpg
Looks good, Eagle One wadding polish works great for that stuff, and can remove all kinds of surface problems that might arise from daily use. Use on the inside first in case it's doesn't agree with the particular metal/clearcoat. I've had it work on stuff it wasn't supposed to, and not on stuff was supposed to(although my can is pretty old now). The oils in to can even make surface rust just wipe off if you let it sit for a few minutes.
Edited by SnakeEyes
I'll have to try that next time. I've been using Mothers for years now, but I don't particularly care for it all that much. It works, but it takes a lot of polishing to get the wheels clean.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,215 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
