Jumped my buddy's patrol car. He thinks his battery is screwed and he's also afraid they're going to decommission his car early since it's been having so many problems. Which would be bad for him because the county doesn't have a new Explorer ready for him. Pool cars haha sucker. I guess hell find out soon since he's taking it in today.
Edited by Chevyguy85
Repaired a 2000 Corvette FOB, well actually I just flipped the battery right side up and cleaned the contacts. This was done at a battery shop too.
Finally washed my truck after a few wks of rain
Ryan B.
Nice, looks to be in good shape. What's the mileage?
144k km so about 89k miles. It's in really good shape, a few surface rust spots, but nothing that can't be dealt with.
Thing looks better than my '07 ... and mine has been a garage queen for 10 years!
Ran into this today
Ran into this today
How much damage?
:lol:
Dang it, if they would just make those for the public without the graphics.....And I don't have to go job hunting soon....
Nah, I'd probably still want a ZL1 anyway.
Edited by SnakeEyes
What kind of problems is he having with it? What year is it?
Cleaned the interior of the truck last week sometime, feels nice having a clean "mobile office" so no windows down for me for a while lol
Besides that, haven't really focused on the truck much. Just been riding my new to me motorcycle every day that it's been nice out
Sent from my SM-N920V using Tapatalk
Yesterday, I modified my tow hitch brake light to "only come on with the brakes, and not the tail lights," by removing the "brown wire." Or so I thought. Turns out, on my '15 Silverado, that the (corner) brake light come on when you lock/unlock, use your hazard lights, or remote start. I can live with those options.
So at night they aren't on unless using the brakes?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
