New from NC
Hey fellas, I've Posted before but I thought I'd actually tell ya what I have. I've got a 78 custom deluxe on 36 inch swampers, 350, sm465, np205, 10 bolt front and 12 bolt rear. 110k miles. Just an old mud truck really. My dad bought it new and gave it to me when I got my license. My DD is an 06 RCSB, white. Nothing special, but it's it's got quite a few options. Only has a Bedliner, low pro toolbox, SI/DO flowmaster 40, and 285 70 17 ATs. I've learned a lot here and I hope I'll be able to add something useful lol.
Hello fellow Tarheel and welcome to the site. My first Chevy truck growing up was a 79 Custom Deluxe. Very base model. Had the 250 inline six, full time 4x4, 3 speed auto, AM radio. A luxury powerhouse it wasn't but your pictures still bring back some good memories.
Thanks for the welcomes! I'm near hickory, I'd. Tell us the town but you've probably never heard of it lol. Yea dad ordered it with the 350 and "big" 31 inch tires and zero other options lol. It had no radio or air. Did have factory dual exhaust. Now has true duals with 40 series flowmasters. Not one bit of smog equipment either lol
Wow the older one looks like a lot of fun could be had in the mud driving it, and your white reg cab is a real nice truck too.
Thanks. Yea mud is everywhere in sc, but a lil bit harder to come by here in nc. To be honest, I really don't remember the last time I used four wheel drive lol. I try to keep my truck in really good shape, I'm really picky about that sorta thing.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
