Does any one else black rims are getting old fast?
I used to really like the look of black rims now its just old and everyone has them and they all look the same. I think chrome will never be replaced maybe some black but not all.
Sent from my BlackBerry 9650 using Tapatalk
I like wheels with the machined finish the best. Mainly because Im lazy and just want to spray wheel cleaner on them and rinse, but I think chrome, and black look just as good.
i think it depends on the truck. some trucks can pull off black wheels, some cant. i see more trucks that shouldn't have black wheels more then should. that's just my opinion.
around me black wheels WAY outnumber chrome, and the rockstar rims outnumber any other kind of rim....
Rockstar rims in general are getting old
Sent from my DROID X2 using Xparent Red Tapatalk 2
black rims are not getting old...just need to be on the right vehicle.
rockstar rims....even though they look really good...are starting to get a little old to me.
I don't see many black rims around where I live....and still like the looks of them. Hopefully, my next truck will be greystone metallic with black rims.
Around here black rims were everywhere but now I noticed not near as many as before. I fad seems to be going out. I never liked black rims on any vehicle, just makes them look to plain and dull.
I like the chrome rims myself.....
Sent from my BlackBerry 9300 using Tapatalk
yuck!
I hate that they are putting more chrome on the 12&13s...which is why my only options were an appearance pkg or LTZ. I sure hope they don't put much chrome on the 14s....that will be a sad day.
Agreed.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
