Not happy
jhm
Well I took my truck to the guy I have known for 10 years, very honest. I told him to replace the fuel pump and while it was there change oil too. He had one of his guys do the work who he claims has 30 years experience. I pick up the truck, go home open the hood and see oil splatters randomly all over. I go back the next day and he reams the guy out for being sloppy. Yesterday the SES light comes on steady. I go back he reads the code as vac leak and re-sets it. He say's gas cap might have been loose, if it comes on again he will have to smoke test the system. Today I read in a Corvette forum that running engine with oil fill cap off will cause ECM to sense a lean mixture and report a vac leak! So obviously the sloppy tech ran the engine with the cap off causing the light to come on. I think that is the end to me giving him buisiness!
  • Replies 52
Ugh that sucks. I would make sure the guy you have been dealing with is the only one to touch your truck the next time you take it there. If you take it there again that is..
Well that's a better story that my father's. He takes his '09 Duramax to dealer for that stupid particulate filter that seems to clog up every 2k miles like clockwork. Gets it back, and while passing a car on the way to my house he hears a loud BANG, and the truck has no power. I find the lower plumbing from the turbo (pressure side) blown right off. Was going to fix it for him, but he says "they F'ed it up, let them fix it" ....... so gets towed back to dealer. They fix it HOURS later. He leaves for FL the next week pulling a 5th wheel camper. Around GA the truck is in limp mode. Goes to a dealer down there. They find the tech installed the pipe with NO O-RING, so that whole trip and then some, the truck was sucking in unfiltered dirty air!
Bottom line is, commission isn't the best way to pay a tech. It is if you own the business .... but not if your a customer!!!
its called flat rate ,it sucks bad for everyone...
i felt like a contractor when i was a gm tech,no work ,we sat on our bench,we barely kept our bays clean,there was a shop bitch to clean up lol
we prepared the quotes ,looked up the labour ,some shops have the advisors look it up
then there are days when ya get a Allison extension housing replacement to do ,,,,do it in the truck and it pays 10 hrs, takes maybe 2.5 hrs ,thats the part that keeps a tech around ,,ya have to be cheatin whore to make any money,,,,
dont get me goin on warranty repair times.......
im out of that enviroment thank god !!!!!
Me too, although I did it in the motorcycle field it sucks just the same.
Now I work for myself. If I don't feel like working, I don't. Dead broke, but I'm happy ... and SANE.
People that have no pride in the work they do should be fired. I cant even think of leaving someones engine looking like you shot oil out of a water pistol all over it then just slamming the hood and moving on. The guy who owns the shop I used told me he gives them 2 chances when they screw up. He said to me "who knows how many customers I lost cause of these guys". I would bet a lot.
Update- The SES light came back on after only a few days after the code was cleared. Bringing it back today after work, he said he would not get to it until tomorrow. I said it seems coincidental that his guy dropped the tank and removed the lines and had to fabricate part of the return line and then the light comes on 2 days later. He said if it turns out it is something the guy did then they will cover it. He's a good guy but I'm getting tired of visiting his shop.
The EVAP system has to be the DUMBEST system ever devised in automotive history. It also happens to be the LEAST reliable system going.
I mean, really .... when was the last time you dropped dead after catching a whiff of gasoline fumes??? :rolleyes: Has nothing to do with the environment. it's a giant revenue generator - nothing more.
Yea, here in CT when they had the old emmissions testing stations they used to screw your gas cap into a fixture to see if it was leaking. Big money maker for the state. Then they found out the company running the system was scamming the state, taking bribes from people who's vehicles flunked.
add little dirt road time and poof,that'll be a zillion dollars to fix the pesky light on the dash sir !!!
They used the smoke machine on it yesterday. He said they smoked the H*** out of it and no smoke leaked out. He is really frustrated. He said to try a new gas cap since this one is original, 11 years old. I bought one after I left his shop. If the light comes on again I am going to ignore it until the emmission test is due. He said he would clear the code, they wont even test it here if the light is on. Thanks EPA!!!
I was never a fan of the smoke machine. I always had better luck slightly pressurizing the system and using an ultrasonic leak detector (basically a very sensitive microphone).
Just found out clearing the codes wont make the truck pass emmissions. The computer they hook up knows if the OBD on your truck has been cleared and if it has gone thru all the test cycles. If it say's not ready you have to drive around for a week or so until it checks all the sytems. Hope the gas cap was the problem since they could not find any vapor leak. CRAZY!
They did know when i cleared my codes, i just claimed i had a dead battery and jumped it to get there
Sent from my ADR6400L using Tapatalk 2
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
