Switched Over To Classic Style
After having the oil consumption issue, the dreaded drivetrain clunk and the fact of paying on a much more expensive truck that I rarely drove I decided to sell the 07 Sierra and moved into a 98 Silverado. I have always loved the looks of this body style and purchased this one from it's 2nd owner. The truck has been well cared for and garage kept, looks pretty good for 188000 miles not to mention no oil consumption or drivetrain clunk lol!
1998 Silverado Z71 extended cab with 3rd door bone stock.
I kept my newly installed 285-70-17 Duratracs from the 07 and purchased some Vision warrior wheels and mounted them up. I added a 2" add a leaf and cranked my torsion bars a little to get the stance I wanted. I also added a 7 pin trailer connector on the back for my trailer lights and brakes, couldn't find a decent place to mount a bracket so I removed one of my license plate lights and installed it there. I spot welded a small piece of flat stock behind the hole so the pilot bit on my hole saw had a place to grab.
Finished product
So a few goodies including a new low profile deep well toolbox and heres the finished project.
Thanks I'm pretty pleased with it so far, I figured worst case senario is I have to replace the engine or tranny someday but the tried and true 350's are easy to find along with the 4l60E trannys.
IMO the OBS are the best looking trucks made, ever. After all, the did make the almost exact same style for 10 years. That one looks really nice, although I have to say rims > 16" don't look right, but JMO. Good find!!
Nice truck, really liked that body style. I was a senior in high school in 98 and wanted one so bad. Then in 2000 I ended up with a 2000 instead
Ryan
whats the inside of those trucks look like are they like the gmt 800s
I like the style of the interior better in my 1990 than most vehicles. The later 400's aren't bad either.
I like the interior the thing I miss the most though is the nice big flip down center arm rest I had in the Sierra with the 3 cup holders. I may try to retro fit one of those in this truck. Interior pics coming soon.
My favorite trucks of all time! Great find, there aren't many in that good of shape around anymore. If I could find one that clean I'd unload my truck on it in a heartbeat, but I'm up in the snowbelt and everyone knows about the dreaded GMT 400 rust issues.
I'm very pleased with it so far, I've been fixing a few minor things, replaced the seal in the output shaft on the transfer case I had an occassional drip there, replaced inner roller pin and door hinge pins on drivers door last night. I located a nice factory stereo from an earlier year that has the CD player built in to replace the current one since it has cassette. The truck has a seperate CD player right below the heat/AC controls but it doesn't work, once I get the other stereo installed I'm gonna remove the seperate CD player and possibly add a CB in that slot.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
