How far do you live from home?
00Silverado4x4
So I'm bored right to the moment and it has left me to thinking....bad thing sometimes...
How far do you live know from where you were born/grew up/from?
Due to military living I'm currently living in Georgia but originally from Pennsylvania. So taking the roads I currently live around 1,000 miles away from where I was born. Since I also moved my state of residence to Alaska, I could also say I'm about 4,500miles from "home."
What about all of you?
  • Replies 32
A year ago I was in the Air Force. I was at Eglin AFB, Florida. 2200ish miles from home of Bakersfield, CA about 45 minutes west of Edwards AFB. Now I'm back but live about 10-15 minutes from family. Close enough for a small drove but far enough that they wont just come over
Sent from my DROID RAZR using Xparent Red Tapatalk 2
900 miles, a shade under 15 hours taking my time and trading convenience for a few extra miles of driving (sticking to the NY throughway instead of I86/I88 makes stops for gas and such faster because it has the service stations right on the highway). Grew up and lived in the same town in NH till March then moved to Michigan.
Man, where do I start...Cedar Rapids Iowa to Vero Beach Florida back to Iowa to Minneapolis Minnesota to Jefferson City Missouri to Colorado Springs Colorado to Las Vegas Nevada to Des Moines Iowa. So, only about 150 miles...
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,399 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
