How far do you live from home?
00Silverado4x4
  • Replies 32
700 miles. Originally from Cincinnati, OH. 11-13 hrs depending on traffic in Chicago.
About 5 minutes from the home I grew up in. :thumbs:
From where I was born, about 300 miles.
From where we moved when I was 3, about 25 miles.
From where we moved when I was 6, about 1750 miles.
From where we moved when I was 12, about 1675 miles.
From where I moved when I was 20, about 1682 miles.
At 28 I moved back to the Pac. Northwest and have lived
within a 15 mile area for the past 16 years.
06Sierra where in PA are you from?
i am originally from outside of philly and now live outside of scranton. still go home almost every weekend
0 yes ZERO, I live in the house today I was born in 56 years ago. I left the house for 20 years but have been in it since 1984. The house has moved about 1/2 mile from where it was when my great great grandmother bought the house in 1866. :jester:
Few hours. The house I own is few hours or so from where I was born, still go home a lot tho. I work 3000kms away, I'm in a plane every 2 weeks.
About 15mins from the house I grew up in. My parents still live there. We spend lots of time with the family there.
Sent using Tapatalk
Oddly enough, Troy, about 2 hours due west of Scranton. Lovely little town in the middle of absolutely nothing. I was born a few miles north of there (still in PA) but that is where I grew up and graduated from. I haven't been back since 2006 to see my remaining living family and a few friends. Love the scenery but job market was a big ZERO so that's how I ended up in the military.
This thread gave me a little bit of an idea...
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Uh oh....now were in trouble....lol
Just because I can't sleep you assume you're in trouble
Well you're not in too much trouble. I'm out of Ambien. That is what causes my off the wall ideas
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
