New Guy from Oregon (well sort of new)
diggerdan11
Hey Everyone,
I figured I would introduce myself to everyone. My name is Daniel and i actually joined this forum back in 2007, but I am sorry to say that I sort of forgot about this site, I actually forgot that i joined until I went to register and realized that I already was. I come across this site all the time when searching on google and every time I tell myself that I really need to join, so here I am.
I am a member of SilveradoSS.com as well as many other forums. Im hoping that you guys/gals will be able to help answer some questions that I may have that the SS specific crowd might not be able to answer.
Here are my 3 GM trucks:
2005 Silverado SS
2003 Silverado 1500HD
1969 Chevy C/20
The 1969 is my project truck that I picked up for a really good price, It already has a re-built 350. Im hoping to start restoring it soon, as soon as I am done with my current house project then i will be able to start working on the 69.
Diggerdan11???
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Diggerdan11???
Yep Thats me! IDk why i did not use Diggerdan11 on this forum when i signed up in 07, I use it on every other forum.
Edit: Decided to change my name to Diggerdan11 so I have the same name on every forum.
So any word on the west coast meet? Haven't been following SS like I used to. I need ideas for this 6.0
I know you can just change your display name and we will all see Diggerdan11
^ I would still like to have a western meet, but no one seem to be ablt to agree on a date. But most say the end of Sep or begining of Oct. I think i just need to pick a day and if people and make it great, if some can then oh well.
When I have a date I will post it up on here and see who might want to come who is on this site.
So now you should include 2 sites. As stated on SSS I am about 4 hours from Vegas.
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
