I like that color
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
So awesome! I actually saw one in that color on my way in to work this morning, and I'm pretty sure it was the first one I've ever seen.
I wanted a Steel Green Metallic Silverado back when I was getting my truck but all the ones around here were only 2WD. I still never see any around here.
Definitely will be a rare color of them all, probably will be a selling point when the time comes lol, cool thing I like about the paint is how an indirect look changes the color.
You like it because it's a GMC that happens to be green.
GM Ad and Promotion Department still sucks. That's what got them in trouble before.
Edited by BigBlueLB756
