Its about 82.5 to 83 to the top of the onstar antenna. Not sure about the car wash. Around here they don't like wide tires at the car wash... I'll try it tomorrow and see.
Hey man, I've got a 14 Sierra SLT and the dealership told me that I cannot have a third party install a suspension lift without voiding the warranty. Did you have the dealership install your lift or did you have a local shop do it? Did it void the warranty at all?
Look in to Magnuson moss warranty act. The lift itself is not under warranty but having a lift will not void your entire warranty. If a part fails... the dealership has to prove the aftermarket part caused the failure. It's still a risk and if something breaks you may have to yell a little louder but a good dealership shouldn't give you any trouble.
7" RCX Suspension Lift
18x10 XD Strike -24 Offset
35x12.50x18 Nitto Trail Grappler
F47B7C67-2EBB-46EA-898E-4AF78EE70471_zps
291BDB96-50D7-4E94-AF98-3D4C92D36AA3_zps
5A82634B-57F7-481F-969D-8E64829E92E3_zps
6A62E2A6-0B88-4CDC-BFC2-B2EECDF357EB_zps
A9A2C035-33D6-42C9-B378-4E2446D95130_zps
Any rubbing?? Did you have to cut any out of the inside fender?
The only rubbing I have is on the drivers side when I turn in or back into a spot or driveway sharply on an incline like a steep drive or a hill but its very little and its on the black little cap on the bottom of the fender like where I guess the dealer puts mud flaps. Its so tiny of a rub im not gonna trim anything
The two dealers I deal with are very different. One holds very strong to not wanting to deal with any truck outside of the maintenance warranty if you have a any combination of lift components (whether it be body and/or suspension) that brings your truck a total of 4" higher. They blame any break on the lift or if you drop the truck. "Oh sir, the reason why your headlight went out is clearly because you lifted your truck 5" and put on bigger tires. The bulbs are just not meant to be at that height"
While the other dealer lets you do YOUR truck the way YOU WANT because it's YOUR truck and you are the reason why they are getting business. You can drop, raise, hell, you could strap wings on it. They still warranty any GM part.
Moral of the story is, you gotta find a good dealer. One that is realistic and wants the customer to be happy on the road and at the dealership.
Well I ordered my 7" lift cant wait to get it on and new tires now I have a 2.5" leveling kit to sell amd 295/60/20 tires nitto terra grapplers with about 10,000 miles on them
Changed out the 35 x 12.50 Pro Comp Xtreme MT2 tires for some 295/65 20 Toyo AT2 Xtremes. They are .5" taller than the pro comps, .5" narrower and 12lbs lighter. Noise and Ride is alot better as well. I also have some chrome center caps coming for the wheels to mix it up a little. If anyone is curious, dropping 12 lbs per tire comes out to 1.5mpg increase.
post-127628-0-57797100-1404351985_thumb.jpg post-127628-0-26597200-1404352015_thumb.jpg
@cataylor..those look real nice and not so much like a car tire like some othe ATs look like. I may be swapping my dick cepeks as well. They are way more agressive tire than what is portrayed on site. There loud and balance worth a crap..like 14-16 oz bad.
Yea, I was worried I wouldn't like them at first just because they weren't MT tires. Once they got them mounted and pulled the truck out I was relieved. They look really good in person, plenty aggressive for what I do and they run so much better on the road. Worth the money IMO. My other tires still had a lot of life left in them even though they had 11K miles on them. Sold them for 1K and recouped some of the cost of the new tires.
Finally! 6.5 inch Zone lift, 35x1250 Atturo MT's. What do you think?
A9FCAAF6-25A6-4619-BDDC-07F0AC0B3E5E_zps
Love it, finally someone else who prefers rubber over metal
Sorry it took so long to get pics of the offset.
Rotten, your set up looks perfect! My BDS four inch should be here on Tuesday. Still on the fence as far as wheels go. Are yours 20x9 or 20x10? Do you know what your offset is? That info would streamline my decision. Thanks.
Is your front wheel sticking out further than the rear?
The geometry of a spindle style lift, pushes the front hubs out a bit.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,238 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
