The geometry of a spindle style lift, pushes the front hubs out a bit.
Oh okay. I thought I remembered watching a video about the BDS kits and they claimed that it didn't push the front wheels out any.
Must've been another company I saw the video about.
Yes, the point of the picture was to show the difference between the front and rear with a BDS kit. I am now trying to decide if I should put some 1.25" spacers in the rear. I don't really know that much about spacers for the rear of a truck. If anyone has any suggestions or opinions that would be great. Also my wheels are 20x9 with 5.75" backspacing. That's equivelent to +18 to +20.
Thanks for the measurements. I plan on adding spacers to the rear of mine. Not all that familiar myself, but I'll be sure to share any info I come across.
I want as little lift and 35s with 18s with little to no trimming what are my options? Would like to keep the ride as close stock comfort.
Guys need a little help please.
I have a 2014 GMC SLE Z71 crewcab shorty bed that I have already done a 2" level on the front and Firestone airbags on the rear. Here is my dilemma...The front of the truck sits at 38.5" and the rear sits at 40.5" with only 5psi in the airbags. I am thinking about adding a additional 1" lift to the front, but am very concerned about the ball joints wearing prematurely. As well as I am unsure if this is even possible. Please give me some options as the truck is nose diving bad.
Changed out the 35 x 12.50 Pro Comp Xtreme MT2 tires for some 295/65 20 Toyo AT2 Xtremes. They are .5" taller than the pro comps, .5" narrower and 12lbs lighter. Noise and Ride is alot better as well. I also have some chrome center caps coming for the wheels to mix it up a little. If anyone is curious, dropping 12 lbs per tire comes out to 1.5mpg increase.
Think that setup with those new AT2's would work on a leveled truck? Edited by 96bigbody
Anyone have the trail grapplers? Im puttin on my 7" kit this weekend and just ordered 35 12.50 20 trail grapplers. To replace my 295 60 20 terra grapplers..
I've had them. They're pretty good tires. Just have to rotate religiously
Lasure, that is pretty typical. In fact, that is exactly where mine sits with a Ready Lift level and AirLift bags. I think you are stuck going with a 3" level that includes control arms, or a full blown lift that drops the differential too. Unfortunately, you've reached the expensive part.
Gotta hate when that happens ^^
a3avegyz.jpg4y4yte8u.jpgty2umy8a.jpgymume9up.jpgmevytaze.jpghumyge6u.jpg rough country 4.75 lift, 20x10 Moto Metal 970's with - 24 offset, 305/55R20 Toyo Open Country AT II's Extreme. Minor rubbing in reverse at full lock on the plastic trim. Not bad at all.
  • Like 4
What you use to smoke the tail lights?
Took it to a recommended body shop and I believe they just painted a thin coat of black then clear coat. It was $135 to do all three lights and they're warranted.
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
    • I am not a NOCO fan for a charger I would leave on a battery 24/7. The reason is, it doesn't really float. It waits until the battery drops to a certain voltage and then charges it back up to 14V. It's better than no charger I guess.
