New to the forum here is my newly lifted Silverado
Sweet! What's the setup?
9" McGaughys (powder coated)
1.5" BL
22x14 American force
37 Toyos
When I get back in town will be getting everything painted to match and other small things
Quick question guys? Can I add a 3" body lift to the Fabtech 6" lift in order to fit 37" tires?
I would think so. Will probably depend on your offset though. I have a 10" lift and my 38s fit fine wth no rubbing whatsoever.
Sent from my iPhone 6+
I don't see a problem with a 12.5" wide tire but if you are going with a 22x14 wheel set up then yes I can see there still being some rubbing. Just do a little trimming and you'll be fine.
Just read the thread where owners of lifted trucks and bigger tires were having issues with stabilitrac. I noticed (could've missed something though) that owners with rough country, BDS, and custom lifts had these issues and that the alignment / possibly the stabilitrac sensor wires were pinched/stretched were the most likely causes. One owner contacted Rocky Ridge and RR felt it was stretched sensor wires causing the problems. Others seem to have corrected the issue by having their truck aligned properly.
I posed the question in that thread and I'll pose it here also because many different types of lift makes are represented here; are Pro Comp 6" lift owners having an issue with stabilitrac?
I've had no issues with my Pro Comp 6" lift and the stabilitrac system. Just rolled 3,000 miles so time will tell I guess.
2015 with 10 inch Bulletproof lift and 38x13.5 inch tires:
Those shocks rode really stiff. The fillings in my teeth were rattling out. So I upgraded my shocks to the Icon Reservoir shocks which are an option with the Bulletproof lift. The new ride is like night and day. My wife and kids will finally ride with me again.
If you've had no issues in 3000 miles, chances are that you won't have any with stabilitrac simply due to the lift installation. From what I've read, stabilitrac issues surface, in most cases, immediately after lift installation.
Did you have your truck/speedometer, etc tuned after the lift was installed or is your programming completely stock?
Edited by Front Runner
Yes, the speedometer was calibrated with a hyper tech programmer the same day the lift kit, wheels, & tires were added. Edited by Fireman_4_Life
Okay, so no other tuning besides the speedometer?
No tuning currently other than having the speedometer calibrated with the hypertech. No issues what so ever. Currently in the market and researching custom tunes. Narrowed down to BlackBear performance or possibly a Diablew custom tune.
Lew for the win!
I'm looking at getting the 3.5" suspension lift kit from RC and I want to run a 305/55r20 with the stock rims. Just curious if any one is running a similar setup or if I would be able to fit that tire without cutting anything and it not rub. Thanks
Okay. Thanks.
