Just an opinion but if I were you and I wanted to run a 33" tire I would look at the 4" BDS lift. I think your truck would perform very well and look fantastic.
Looking for some input, if you have a negative comment don't even bother. This is my first vehicle and this is what I could afford, 14 Silverado 2wd v6 with the 3.23 gears. I read pretty much all the threads. I like how lifted trucks look and I'm currently on a level with 33s and the truck performs just fine. I want to do a 6"lift but keep my 33s. I know this gear ratio isn't the best to go with 35s and honestly I don't have money to throw like that. Will adding a 6" lift have a big effect on my truck? Like messing up the gears or does that only get damage when trying to push bigger tires? What are the cons of doing this to this particular truck? Thanks in advance
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
I have a 2014 lifted with Rough Country 7" and 49K miles and no stabilitrac issues at all
Is your truck an early 14 model? It's seems, by what I'm reading, that later 14 models and 15 models have been having issues with stabilitrac. Maybe slightly different programming? Not sure......
I haven't seen where Pro Comp owners have been having any problems with stabilitrac by what I've read. I guess it could be that they haven't chimed in if they have.
Edited by Front Runner
Let me know what you guys think of my newest build.
2015 GMC Sierra 1500 - Predator Edition (Stage II)
  • 6.5" ReadyLift w/ Add-A-Leaf
  • 22" Fuel Maverick on Fuel Gripper 35x12.5x22
  • Painted Bushwacker Flares
  • Line- X Spray In Bedliner
  • Access Lorado Tonneau Cover
  • Lund Bullbar w/ LED
  • 60" LED Tail light
  • GM - Borla Dual Exhaust w/ Black Chrome Tips
  • GM - 4" Assist Steps
  • GM - Smoke Window Vents
  • GM - Painted Grill
  • LED Headlight Bulbs
  • Custom Leather
  • Xpel Protective Film
  • Crystal Fusion
  • Zurich Shield Elite
  • WeatherTech DigitalFit Floor Liners
Sweet man!!
Unsure my build date but I bought it mid April 2014
Just read the thread where owners of lifted trucks and bigger tires were having issues with stabilitrac. I noticed (could've missed something though) that owners with rough country, BDS, and custom lifts had these issues and that the alignment / possibly the stabilitrac sensor wires were pinched/stretched were the most likely causes. One owner contacted Rocky Ridge and RR felt it was stretched sensor wires causing the problems. Others seem to have corrected the issue by having their truck aligned properly.
I posed the question in that thread and I'll pose it here also because many different types of lift makes are represented here; are Pro Comp 6" lift owners having an issue with stabilitrac?
thats what my problem was, at full turn lock to lock the wires where being pulled apart causing the stabilitrac issues, after cutting the try wrap off and let the wires hang I've never had any other problems
In the rough country kit I just installed they tell you how to get more slack out of the front and rear wires. Before I put my truck back together I turned the steering too full lock in both directions to make sure I had slack at full droop.
Just got my truck back about 4,000 miles ago. Installed:
Zone 6.5" lift
20x9 XD Badlands
35/12.50 cooper st maxxd380c0b2d59f03a72e448132679e445b.jpgc27059806c54519d52a999fdd2e905b5.jpg
Great looking truck! That makes me want to go back to chrome wheels, I think the tire size gets lost with the black wheels. I like the coloratched door handles, and mirror caps also. What are the specs on your wheels, I might push mine out a little more, just my preference. Keeping them tucked in helps keep the truck clean, but I prefer a little wider stance.
20x9 with a -12 offset. I'm looking for a little more stance, I've thought about wheel spacers but I've heard bad things about them
Strange, that's exactly the same specs on the wheels I have. Must be the angle of the photo.
As long as you buy and install a quality Hub Centric spacer they are fine. I have 1.5" spacers on my rear hubs to correct the track width and after >7k miles I have had zero issues.
Quick question guys? Can I add a 3" body lift to the Fabtech 6" lift in order to fit 37" tires?
should definitely give you enough clearance
I don't think you will fit 37s with that, I have 9" suspension and had to add 1.5" body to fit 37s and still rub some. But I also have 22x14 so I'm sure that is a big factor
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
