Thanks guys. I'm just looking to run 20x10 on 33s. I might even just do a 2.25 or 2.5 level.
Check out customwheeloffset.com, you can look in the gallery and specify vehicle and wheel size. Should give you a better idea on levels and lifts on 20x10s. Heres an example: 20x10 on 33s - https://www.customwheeloffset.com/wheel-offset-gallery/12133/2014-gmc-sierra-1500-fuel-maverick-rough-country-suspension-lift-5in
I just ordered my tires and wheels from custom offsets. Great prices and everything arrived perfect, only 3 weeks after I ordered them lol. Check out my gallery, running 2" level on 20x10 on about a 32.5" tire. I can also vouch for skyjacker. I have had a couple of lifts from them in the past, they are on the same level as all the other big brands in terms of quality and fitment.
Will do. Are you under CWilliams on there as well? Mind linking your gallery?
Edited by gary.smedley
Yea I have the same username on there as well. I submitted my pics yesterday but they haven't been added to the website yet last time I checked.
Well they wont get to it till tomorrow now.
Blame the fires we are having right now in the panhandle of Texas and thats where the shop is.
2 of 3 boxes were delivered. But tires and wheel spacers for the rear arrived without a hitch, tires are mounted and roadforce balanced, rear is done and most of the front is done. Just need those spacers or whatever they are that was sent for the 6" instead of the 4"
Sent from my SM-G935V using Tapatalk
Any updates? Looking forward to seeing it!
Sorry... Been really busy with work doing 7 14s so its dark when i go in and when i get out...
  • Like 4
Nice man! Did they have to trim anything? Looks great!
No timing at all rubs just a touch at full lock and the back has a 1.5" spacer to even out tje look.
BDS 4" basic lift rides a lot smoother tjen expected but not like stock like most claim.... It's a tad rougher but not much.
Yeah a lot of people claim their trucks ride better than stock but half of them are full of shit lol
  • Like 5
I think the tires have a lot to do with it but good greef the R/Ts are quite.... I was expecting more howling.... Again nowhere near stock or real ATs but much better than the MTs
Agreed for sure, they do ride nice for such an aggressive tire!
If you get a chance to get a photo from the side just to see how much the tires stick out, i'd appreciate it! I really want to get the Zone 4.5'' lift with 35's but I don't want to have a rub that I can't fix/trim. Also, you guys suggest the RT's over the MTs? Just noise level? Or ride comfort as well? Thanks!
Tires stick out about 2" i would say... Ill see about getting a pic during the day for ya..... Measly 8hr shift on Saturday this week so ill wash it and post up some pics
Offroaded a bit on my way home and i can only get it to rub on the liner in reverse at full lock.
Perfectly fine with me!!
With the Fox coilovers my truck definitely rode better than stock.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,734 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
