How are those headlights? Do they make a huge difference at night? Was it an easy install?
They were easy to install but today I tried to install HID's and that didn't go well. The stock light is not that great but they do look great .
cf372db73350069b45e4ae4a08432383.jpg4766d902652ec94e149aa5389b6736ac.jpg6ec62de1af35e0687f0ba7bc03afe4f2.jpg7d225a99b38b624b5478863ad7ec020e.jpg
Finally got my lift, absolutely love it
What are he specs of your setup? What are you doing with your old wheels and tires?
I want to sell them actually
Fabtech 6" lift with back wheel spacers Anthem A742 rims wrapped in Toyo 35x12.5x20s
That's the setup I want eventually but I think I'm going with BDS or full throttle.
How much you looking to get for them
1800 ish tires are only 3000 miles in or an offer
Picked up my truck today after getting a lift installed. Installer installed Prorunner ss on front to level the 4 inch Procomp lift.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Can I remove the strut spacers from my zone 6.5 and add fox coilover or BDS strut? Will everything work together
Sent from my E6853 using Tapatalk
Yes
Sent from your sister's house
Does anyone know who manufactures the coilover that Rocky Ridge uses on the front of there Alpine series trucks with the Pro Comp 4 inch lift?
Best bet is to contact procomp since it's their lift and they get the strut
Lift is finally done!
Zone Offroad 6.5" Lift
Fuel Renegade: 20x10 -19 Offset
Cooper Discoverer ST Maxx: 35 x 12.50
  • Like 3
Lookin good.
Any rubbing??
Lookin good.
Thanks bud
Any rubbing??
No sir. Thankfully I do not!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
