Just ordered a Fabtech Gen II 6" lift
Awesome don't forget to share the pix when it's done!!!
Saw this on another forum (See below). Some guy was asking about lifting his Ford truck 4'-6' and putting 35s on. This is a response he received. What do you guys think about it? Personally I'm looking more toward a 4in with 33s but found this intriguing as a few people agreed with the dude. I found it funny it was on a "Lift" forum...I guess the guy likes to troll or he is a public servant...
"Lifting a Ford and lifting a Chevy are 2 entirely different conversations as they are completely different animals. Lifting a GM requires the best of the best in quality of parts and design of the system. There isn't a cheap lift kit for a GM.
As a former business owner and someone who used to install lift kits professionally, I would strongly recommend against EVER lifting a 1/2 ton truck. The running gear in any of the Big 3's 1/2 ton trucks is simply nothing more than Chevy Caprice, Ford Crown Victoria, and Dodge Dakota/Durango respectively. The increased loads put on the transmission and differentials with 35" tires is tremendous.
Dodge is so bad now that they took their Caravan trans (which has never lived an adequate life anyway) took the transfer gear set and differential out of it and put it in their Dakota's and 1/2 ton's.
Can it be done? Yes, anything can be done. Will you end up with Powertrain issue's? I guarantee it!! I've seen it hundred's of times. $$$$$$$
Any input is appreciated. Azz.
Edited by Azz
my 2016 Chevrolet Silverado LTZ Z71 with a 5 inch Rough Country lift on 20x9 BMF BATL wrapped in 305/55R20 Nitto Terra Grapplers
  • Like 3
looks very nice, any pictures of front / rear of the truck? what specs are the wheels? like backspace, and offset?
did you do the install yourself or had a shop? how much was the lift and install cost?
sorry for all the questions!
Sweet ride, I like those wheels :D too bad BMF changed there name to SOTA and its getting hard to find wheels that are stamped BMF.
So ever since I had lift n tires and gears done I've been needing to recal my speedo. Was off a lot. Finally got the balls to tune it with a Diablo Intune i2 yesterday. Did the 91 tune with corrected gear ratio, corrected tire size, firm shifts and DOD off. Took a ride today to a buddies house and this is what I am getting for mpg now. I was pleasantly surprised.
Solid 18 mpg combined highway/town.
Cruise on 70 = 18.1mpg
Cruise on 75 = 16.2mpg
Off highway back roads to his house... get this...over 19mpg!!
Tranny shifts way better. No V4 crap. All around better response and drive.
A7540F44-72D9-42FF-A5C8-1F0CDDC29271_zps
Edited by Cato
That's awesome brotha!!! Great to hear that, I've been hesitant to pull the trigger on a Diablo tune as I've had and liked the edge tuners. But I have all Apple stuff and edge isn't OS X compatible and Diablo is. So needless to say your happy with it and definitely have a proven mpg increase. You like the power as well? And what gears did you put in? I was thinking about re gearing to 4.10's
I really like it so far. Honestly shocked at the mpg's I'm getting. I put in 4.10 Yukons when I had lift and wheels/tires done. Very happy with the choice.
Right on good to know, thanks for the info man Edited by Abearclaw
2016 6.2L All/Terrain 4x4
8" total lift. Zone 6.5 plus Bilstein shocks set at 1.5" and a 1.5" AAL.
35.5" tires Goodyear Duratracs.
  • Like 5
Does it ride better with bilsteins? I have a 16 all terrain as well with zone 6.5 and I find it rough
Sent from my E6853 using Tapatalk
Yes much better. I thought the Ranchos up front and the zone shocks where good until i put the Bilsteins on. Way better. Truck feels smother and more panted to the ground.
Do you have Bilsteins in the back as well?
Sent from my SAMSUNG-SM-G930A using Tapatalk
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
