Any pics of your set up? Also looking to go with a 4" and stock 20s with 35s
Yeah no prob here's a few pix
6af11a6ad40502567e73e2408e0e6420.jpge8fa727c3ca5c707826d8b8a6281c39c.jpg42bdeb5673e2ff7ec2453032ad79662e.jpg
If you want any other pix specifically let me know
Looking good!
what was you issue with superlift. i had their kit on my dodge 2011. quality was great but i had some vibration issues that i think was just a dodge issue. they gave me some issues but eventually came to a resolution. shocks that came with the kit sucked, but they upped me to bilsteins for free. i was considering their 8 inch kit for my 15 or the 6.5 inch from zone.
I've had several BDS lifts and they are top quality with excellent service. I'm currently running Zone which is made by BDS and their "generic/budget" kit. However the zone kit has been an excellent quality kit. I've had Superlift and wouldn't consider them agsin
Sent from your sister's house
terrible quality paint work on crossmember drops. Way too may creaks and squeaks. The leaf pack kept separating due to lack of clamps, so I had to clamp it myself. This was on my '08. I've loved all my BDS and Zone kits
looks like im going with the zone 6.5
i love my Zone on my '13. Hopefully Zone offers the full strut replacement soon I'm the K2xx trucks
what exactly is that? does that eliminate the spacers?
The BDS and Zone kits are not the same, made by same company yes but different. The economy lifts achieve the lift via a spacer sitting on top of the strut. The BDS kits use completely new and longer struts which is why it costs more. So if you have a spacer type lift you are still running on stock parts and the ride quality will be the exact same as stock until you change out the load range on the tires your running of course.
So does the struts help any? Or would the spacer with original strut be just the same?
Sent from my SAMSUNG-SM-G930A using Tapatalk
My 2015 z71 6inch BDS, 20/12.5 American force blades on 35 Toyo's
Did the plates come in red or did you have to have it painted? That is a nice setup. I was looking at the 6 inch but it seems pretty high in your setup, might have to settle with the 4.
Sent from my SM-N900V using Tapatalk
with full struts there are no spacers. The struts handle the weight of the heavier tires better as well. A full coilover like Fox is even better however much more $$
Edited by jimmyboy8301
So if you are looking for a product that last then a BDS lift would be a better investment. I came up with the conclusion. Why are people going to go cheap on something like that when most people at least are paying $40k for their truck. Is $800 really that much more for a truck that cost that much.
Looking good!
Thank you my friend! I dig your set up as well!
BDS and Zone are the SAME. The angled cross member and kicker braces are the only difference. Once Zone offers the full strut that kit it just as good IMO.
Yeah some people look at it differently and I'm with you, I don't understand why anyone would cheap out on such a critical component. It's like tires. I don't know why you'd cheap out on those either, they're literally the only thing that connects you and your truck to the road.... Just my 2 cents but obviously everyone has different perspectives
But they aren't cause the Zone uses the original strut and adds a spacer while the BDS replaces it with a brand new strut to compensate for the lift. Correct me anyone if I am wrong.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
