d8818ba6523b014c101a29be52fcdcc0.jpg793394573d7722a8854c410c1676faa6.jpg88aa5dc0624249b5ed1b9babf214b38c.jpg9b644f16533b3df2d590821d311461bf.jpg
That's a fine looking ride.
Thank you!!! I couldn't be happier with how it turned out
Thank I really appreciate it!
Well, my Fuel Mavericks are -24 offset because I wanted to add bushwhacker fender flares. I wanted the wide looking stance and if I went with -12 they would be tucked under the fenders.
Any pics showing offset with lift? I am currently running 285/75/18s on 18x10 -24 offset on 2.5 RC lift/level. But looking at 4-6 zone/BDS lift. And wanna see how far out they stick. Edited by Horner21
Need opinions. Looking at 4-6 inch lift to clear my 18x10 -24 offset w/ 285/75/18s. Don't want to go to big like the setup I have now but to much rubbing due to offset.
Just got mine back today. Zone 4.5, with 18x9 Black Rhino Sierra wheels, 33x12.50x18 Toyo RT. Will be upgrading tires next week to General Grabber (Red Letter) 35's.
Sorry only pic I have as of now. It rides great can't complain.
Clean truck any more pics? Looking at getting 4-6 inch lift. Any complaints? Edited by Horner21
I have a 2014 GMC Sierra all terrain with 5inch rcx lift kit , 20x10 rockstar rims with -24 offset and 305/55/20 copper zeon ltz tires , amp power step , bushwaker pocket style fended flares , boral exhaust with metal mulisha 4 inch tip ... Looking to put 1.25 rough country or 1.5 zone body lift to fit 35's DFD72325-B97F-4856-8878-9A39CE53EAE4.jpg58D6ADDD-DD0B-4295-A056-58AA3C086C7F.jpg0B87492D-8483-4493-9835-52660D324184.jpg
Clean truck how are you liking the RCX 5 inch? Looking at getting a 4-6 lift. Did you use the bracket kit or knuckle it? Any complaints with RCX lift?
Hey everyone.
For the guys running the Mcgauphys 7-9 lift can the fox coilovers that cognito offers work since they are for cognitos 7-9?
Or if anyone has looked into running the fox coilovers with the McGauphys and know the correct part number that would be awesome too.
Also to ditch the blocks that come with that kit anyone know what size deaver springs to use. Looking for either level or the rear slightly higher.
Would love the Cognito 7-9 but the quote I got was $$$$$.
Deciding between 35s or 37s.
James
-24 wheels usually stick out pretty good. You should look at a rough country 5 inch bracket lift that keeps the track width stock. The knuckle lifts wheel push a -24 wheel out pretty far.
I am looking at them but wanting opinions and reviews on that lift.
Well I dunno man but personally I like the wheels and tires to not stick out and look a little more factory, allow for taller tires, etc. the BDS and zone lifts as well as most others will increase front track width. I have factory 20's and the fronts stick out MAYBE an inch so with anything 0 offset and negative you are looking at at least an inch and a half in front and greater. I also don't like spacer lifts. That's why I got fox coil overs so I can use more suspension. That's my opinion, but as far as reviews go I actually have heard from a few guys that the rough country lifts aren't very high quality. I've never ran them tho.
I am ecstatic how the zone lift works on my 2016 Sierra! Also has the ranch I front strut assembly! I have owned several truck lifted 6" or higher and this is the most stable smooth riding setup I have ever been in.attachicon.gifimage.jpeg
Looks good. Whats your offset? Also you got any views of the wheels sticking out?
Knuckle lift is easier to install and usually cheaper if you are comparing the same brand. Your wheel will stick out beyond the fender and you will have to run rear spacers in the rear if you want it to match. The bracket lift will keep all of your stock angle and stock track. Basically the way I look at it is my truck looks like it is 2500 HD that is maybe an inch taller. It looks like something the factory could build and is not overstated. I could not get away with a lot of the set up a that people run on here in Massachusetts Technically I am illegal now. But looking stock brings no attention.
Are you running the 5" RCX Bracket Kit? If so how do you like it? I am looking at that kit beacuse I am already running 18x10s -24 offset and dont want my wheels/tires sticking any further out then they are. Also anymore pics?
Yes this is the bracket lift. Only pics I have are the ones in this thread when I talked lk about my build and the one in my signature. Also I saw you ask chandler . His is also the bracket lift. It was mentioned easy on in this thread.
Almost forgot I love the lift. The shocks not so much. But I only paid 1000.00 for the kit so I can afford to upgrade the shocks. Fronts have the factory Ranchos which are fine by me. What other pics are you looking for I might be able to take a few more.
Edited by mrhonestlyinsane
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
