Iridium metallic I love it and 15 percent front
Sent from my E6853 using Tapatalk
Mines the Chevy Tungsten. Got a 3 in level but with stick rims and tires. Man I can't wait till I get some nice rims and tires. She looks good now but like yours once new shoes go on they look mean
Sent from my Nexus 6P using Tapatalk
Sorry first time uploading
What size fox coilovers are those 2.0 or 2.5's and they came with the bds kit right, or did you buy them separate?
Sent from my SM-G925V using Tapatalk
Those of you with the 7-8" Mcgaugheys, did you get the economy or the more expensive one?
Reason I ask is because I have the all terrain with teh skid plates already, dont want to spend the money for nothing!
Does anyone have a picture with a 3" Performance Accessory body lift on a 14/15? I already have a 2.25" Pro Comp Level Kit installed and I am thinking of getting a more economical 3" lift for the body. Thanks!
I have a 3 inch performance accessories with a 2.5 inch rough country lift on my 2014 Silverado
Sent from my XT1080 using Tapatalk
It's the kit from bds
How much of a pain in the butt was installing the body lift? How long did it take?
I did not install it I did the level lift kit 2.5 but the body lift I took it to a shop in McAllen Tx they charged me 600$ parts and labor. I can beat a price like that I'm from Houston and they were trying to charge me 1800 in a shop here in Houston I was like hell naw so I looked around n found that shop n got it installed there no plms at all runs great n looks great
Any body have trouble getting Camber in specs? What options are out there if so? Upper control arms? Camber kit bolts?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
