I like the 6" lifts but it just looks like the tires are too small when they are AT type. The MT look perfect with the 35s. What lift are you going with Nate? looking forward to seeing pics
I'm doing the 6" and putting Toyo RT 35x12.50x20 tires on. I narrowed it down to either the Mickey Thompson ATZ or Toyo RT. I went with the RT as they're more of a hybrid between an AT and MT tire. I agree the MTs look awesome, but my truck is my daily driver and it will see more pavement than dirt/sand/snow. Still wanted a tire capable of off-road as I'll take it off pavement 1-2x per month (I'm currently doing that but I'm limited by ground clearance). Truck goes in Monday for lift, tires and power steps. Will post pics Tuesday or Wednesday.
How does it handle?
It rides extremely smooth. I'd say it's very comparable to stock. My previous truck was an 07 Nissan titan with a 6" Fabtech Coilover Lift and this rides way smoother.
You come through Victoria or port lavaca ever?
I have the rc 2.5 on my 2014 slt allterrain with 295/60/20 on the stock 20" all terrain wheels they do rub and I removed the rear air deflectors u will get rubbing with those they are Nitto terra grapplers there specs r 34.45" tall but I love the look!!
Do you have a pic of what this looked like when you had it? Thanks
Leveled
I sure like the look of that, but what did you install? Lift? What size are those wheels and tires?
Ha, never mind I just needed to pay more attention!
Edited by Go Ordnance.
Finally had some time to take a few photos since I got her back. I'm pretty damn happy! 9" McGaughys suspension, 1.5" Zone body lift, 37x13.50r22 Toyo MTs, and 22x12-44 Fuel Maverick D260 wheels.
  • Like 3
Good looking truck Pooj!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
