You think? Even with the Tire size?
Larger tires always look better IMO. If you go 4" then 33's look great. If you go 6" do 35's
I like the tires on there. Of course i'd like to get 35's. But the ones i have are just over 32. I'll probably do the 4"
Pics when your done bro! :)
Added some Iron Cross Patriot running boards.. Like them better than the factory chrome ones. They tuck higher up so it adds to the looks of the lift. IMO
Just installed BDS 6" with fox rear shocks and leaf springs instead of blocks.
Tires are Mickey Thompson 35x12.5x20
Wheels are Fuel Hostage 20x10 -12 offset
Hypertech Max Energy programmer.
No rubbing
Also had exhaust put on. True dual.
The front does stick out more than the back. I believe the lift pushed out the track about 1.5 inches. I did have a Rancho 2.5" leveling kit. It rode horribly. The BDS rides much nicer.
  • Like 6
Hey guys. I've loved seeing the trucks. I want to keep my factory 20s and get 35x12.50. No rub and I do lots of Offroad travel and work... That being said I'm lookin at zone 4.5" and 6.5". Which would produce the best look and the least issues rub turn and flex wise ? Pictures with factory wheels would be awesome. Or if anyone wants to sell me a set of A/T wheels!! Oh trucks a 2015 GMC CC standard bed 4x4 w/3.42 and 5.3l
Edited by skallywag
I love the stock rims with aggressive tires.....toyo's 35x12.5x20 on 6.5" zone lift without spacers and at full loack both ways in forward and reverse no rubbing at all......i will have more pics when i get in wednesday....i think i sent (quoted) these pics to you the other day unless this crappy internet offshore didnt let me....
Looks sharp!
4.5 may not give you the clearance. I get minimal rub on drivers side with wheels cut to the left going in some driveways when the shock is compressed & mine has a six inch lift with 35X12.50 on 20X10 inch rims.
Any chance on getting some photos? I had 20x12's shipped to me, but they were Ford bolt pattern, so I had to send them back. Now I'm on the fence again. People are telling me the 12's will rub really bad unless I lift 9+inches. I don't want the too much lift, not enough tire look, so I might go back to 10's with 7" of lift.
Per your request. I get a slight rub on the inside of the wheel well on the side by the driver's door. Only enough to rub the paint off of the inside edge of the fender flare.
post-151288-0-27153700-1461554165_thumb.jpegpost-151288-0-51254300-1461554190_thumb.jpg
Thanks, great looking truck. Such a pain in the ass trying to figure out what setup to go with. Pretty certain I'm going with Mcgauphy 7-9ss, with chrome wheels. just on the fence about wheel width/offset. Thinking I should play it safe with a 10" wheel
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
