15green, going from a stock tire( assuming you had a 31 inch to start) to a 34 inch.. Is there a noticeable difference in power loss? Meaning effectively running a 3.12 now vs 3.42? with stock tires
Sent from my Nexus 6P using Tapatalk
My stock tire was 265/70/17. So I went from about 31.5 to 34.5. I have 3.08 gears. The only difference I have noticed is during take off. Its a little slower off the line, but I'm pretty light on the accelerator anyway. My stock gas mileage was about 21 mpg and now I'm getting 18 mpg.
Sent from my VS980 4G using Tapatalk
Got the zone 6.5 on my 16 Sierra and it rides really rough. Going over dirt road with potholes and bumps I find it hops a lot and sounds like the front end is falling apart lol. What would the best way to get a better ride be? Bilsteins up front or perhaps the BDS strut? I know it's a lifted truck so it's gonna be a bit rough I just wanna get it a bit smoother. Thanks
Sent from my E6853 using Tapatalk
Ordered the 6" BDS lift and 35" toyo RT's this past week. Just wanted to thank everyone for the loads of great information I have been reading off the boards here the past several weeks as I researched for my truck. Special thanks to all the guys who replied to PMs. I will post pictures back on the forums once complete!
  • Like 3
Where did you order your lift from and how much was it?
I ordered it from Go Big Truck Performance in Ventura, CA. Privately owned shop that is on BDS' lists of go to vendors. They sold me the 6" lift for $1900 (no fox shocks at this time... debated but decided to hold out and see how I like the performance first). Toyo R/T 35x12.50x20 tires were $380 each. Install & alignment = $700. Totaled up to just under $4400 with tax. I elected to hold off on re-gearing my truck for now. I have the 5.3L with 3.42. If I re-gear, then I was quoted at $2k for that.
Link to local shop: http://www.gobigtruckperformance.com
Has any one fit a 33x12.5 on a 2016 GMC Sierra 1500 with a 4" readylift sst wanting to know if it will fit and what offsize and backspacing is needed
I have 305/55/20 -12 offset on my 14 Silverado with a 4" SST lift, rubs the backside of the inner fender at full turn in reverse... I'm in the middle of pricing out a 7" lift to improve the ride, and run 35's
I'm doing this exact as well. ^^^ Truck goes in next Monday for the overhaul. Nice job cNate. Waiting for pics. : )
6" Fabtech lift with Fuel 20x10's on 35x12.5 Nitto Terra Grappler G2's
Sweet ride! Almost got those exact rims! lol
The shop owner has a few trucks ahead of mine. Hoping to get mine in end of this week or next for the install. I will definitely post pictures. Looking forward to seeing pics of how this stup looks on your Chevy! I originally wanted the Silverado; I went from an 09 Subsrban LTZ to this truck. My brother got the Chevy in white so I went GMC in black. Both designs look great. GM really nailed the design on these trucks!
Totally agree! ^^
Anyone done a MotoFab Level? Not crazy about Rough Country because I heard it was plastic. Link below for MotoFab...
http://www.amazon.com/MotoFab-Lifts-CH-2LM-Leveling-Pickup/dp/B00KOU2UYU/ref=pd_sbs_263_1?ie=UTF8&dpID=41lhTM173RL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=19RE9TNWMYFS65CH67T0
I bought the 2" motofab level for $27 on ebay. I plan to install it this weekend. It looks really nice.
let
let us know when you install and post pics!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
