6" BDS + 1.5" Zone BL. XD Series 820's 20x12, -44 offset on 35x12.5 Toyo MT 3c236f3882bfe944797daabb3ae4c330.jpgfd6c3eef7ab478e298e2c5cacc6aec45.jpg2e31c8f465d9b007f85ee79c5f570fe6.jpg
  • Like 3
Got an odd question I asked in another thread but this place is more appropriate I think.
If I lift my truck 4" will the truck actually stand a true 4" higher or is there some sort of "settling" that takes place and it may sit lower?
I'm trying to figure out exactly how tall my truck will stand.
Stock it is 74" then if I add 35's (that is 3.5" taller than my current tires), then a 4.5" lift the truck should stand 82" high...is that correct or am I addding something wrong?
Just bought a new sierra, debating on lvl/33's or 4.5" lift/35's for garage fitment. Garage is 80-81" high.
Thanks!
Exact height could vary depending on wheel width and how much air you run in the tire. I can tell you with a 6" Lift and 35's I clear my garage just fine with a 7ft door.
Any chance u know the exact height to the top of your truck(shark fin)?
My trucks front fenders was 36 inch stock. A 2 inch rcx level raised it to 38 inches and a 2 inch taller tire raised it to 39.
You have to remember you split the tire height difference in half.
That being said I took the level out. Using the same tire I put in and rcx 5 inch kit. My front fenders now sits at 42 3/4 after settling. That means I got 5 3/4 inches out of a 5 inch kit. You can't trust what they are claiming the lift size to be.
I even emailed rcx because of lift laws around here and stated it was true 5 inch kit. Before settling it was 6 1/4 inches higher. I sat in the bed of my truck and my wife drove it out of the garage. I clear the 7 ft door by maybe 3 inches
Would it be possible for you to take a shot down the side so I can see how far they stick out? This is the same setup I am looking to get, but am unsure of how far they will stick out.
Here ya go.
Perfect! Thanks a lot. They don't stick out as far as I thought.
Yeah not terrible, but I picked up a pair of fender flares for mine. Going to install them this weekend. They definitely stick out enough to chuck some big rocks at the side mirrors, lol.
Gentlemen,
I'm in the market for a lift on my 2015 Silverado 1500 4x4 and wanted to see if anyone has used the 4.5" Zone suspension lift with 33's yet? I tried looking thru the entire thread but 149 pages is pretty extensive. My last truck was a 2011 Silverado with a 3.5" X 1.75" suspension lift on 33's. I had the 20" x 9" KMC XD Cranks with zero offset running 305/55/R20 Trail Grapplers and ran into some rubbing issues turned in reverse. That being said, I was hoping the 4.5" would help with that. I haven't decided on the wheel just yet, but i do know I want to continue with the same tire as before. Any suggestions on offsets that would fit for possibly a 20" X 10" at most.
Lift I am considering;
http://www.ebay.com/itm/2014-2015-Chevrolet-Silverado-GMC-Sierra-1500-4-5-Zone-Suspension-Lift-kit-4x4-/171557627846?fits=Year%3A2015|Model%3ASilverado+1500&hash=item27f1a1a7c6:g:d7YAAOSwLzdWTSwq&vxp=mtr
Also, the lift on this page states "All wheel drive models require drive line modification"???????
Any help is much appreciated.
Alright question of the day...
I know that a 35/12.5R20 fits on a stock wheel with a 6'' lift, but will a 37"?
It might,
I saw a sierra a few days a go with a procomp lift on the stock AT wheels running 37s....probably rubs like a mofo ...I didnt ask the guy but man it looked sick. Didn't have my phone on me to take a picture.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
