Sweet 2016^^.
Ive searched all over. Has anyone tried or test fit a set of mtz 36x15.50r20s? On a 7.5 rcx or a mcgaughys 7-9"??
this im sure has been addressed but
2014 Silverado LTZ Z71 2inch level.
can I run 20x9 -12 with 305/50/20's?
I currently have 20x9+19 with 305/50/20's and no issues at all but I want a wider stance.
I am thinking of going with the Zone 6.5 too. Did you install the add a leaf in the rear? What are your front and rear fender measurements now?
Sent from my SM-T710 using Tapatalk
Measured today all fenders are 45"
Sent from my E6853 using Tapatalk
Thanks man! Just order my Zone 6.5 today. Hopefully, I'll have it installed next week.
I'm trying to do some research on what I want to do to my truck. I originally thought about just leveling out the front, but would it be best if I plan to get a small lift to just do that instead of even worrying about leveling? The most I'd really want is about 3 or 4 inches. So would I just get a lift kit and put 4 inches on the front and 2 on the back to level it out? Also, would a 4 inch lift make the vehicle too tall to clear a 7ft parking garage?
The 4" kit from BDS would be right up your ally. Several trucks on this site are running that. Also the rear lifts with the front but comes out close to level. IMO they look very nice and way better than my truck did when I only had a Rough Country 2.5" level.
Here is my contribution. 2016 GMC 1500 Denali with 6.2L Fabtech 6" Lift, Moto Metal MO970 20x10 -24 wheels.
  • Like 3
That looks sweet!
Sharp!
Just ordered the Rough Country 3.5 kit.
Any issues with 20x9 -12 with 305/50/20's?
Yes I had to trim some. They catch in reverse it's tight but not unmanageable. Most trimming was done on the wheel well plastic.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
