I believe Zone has the specs on the website for the alignment. I will tell you that with those 36" Duratracs you will need to do some extensive trimming! I have 35's and had to do a lot in the front and back. I still get a little rub in reverse at just under full lock. I'm glad I went with the 6.5"... 7-9" might have been better to avoid any rubbing. Also make sure you throw the zone add a leaf in yours, especially since it's a crew cab. I'm glad we did. It doesn't cost much.
Shouldn't have to trim that much at all if the offset is right. Can fit 35s with plenty of room. You have 20x10 with -24 that's why you had rubbing
Sent from my E6853 using Tapatalk
Edited by zoomiejr2
Well, my Fuel Mavericks are -24 offset because I wanted to add bushwhacker fender flares. I wanted the wide looking stance and if I went with -12 they would be tucked under the fenders.
I agree it looks the best, when I lift my new 16 I'm going with a higher offset, I cant bring myself to trim a new truck lol
Hi all, new member here, but i've been reading up and down this thread for a couple weeks trying to find the right lift/tire combo for my 14 silverado CC. I currently have a 2" leveling kit and 285/65/18 on it right now, but I want more lift. :)
I think i've narrowed my lift down to a 4.5" zone lift. I have seen several members with this lift, but mostly with 20's, not 18's. I may have overlooked them, but is there anyone out there running the 4.5" zone with 18's? what size tire are you running? I've got my eyes on a set of 18x9 +0 offset (5"BS).
thanks for your time and help. Any advice is welcome and appreciated.
I have the cousin to this lift; a 4" BDS. I have 18x9 Fuel Cleavers with a -12 offset and 305/65/18 BFG KO2's. BDS had suggested I try a 0 offset wheel or even slightly positive to avoid trimming. There was minor rubbing at full lock in reverse, but I've since fixed it.
Josh
Anyone running the pro comp 6 inch on these new trucks, how much does it increase the front track width?
About 1.5 inches on each side.
Perfect thanks. Was leaning toward BDS Or zone but looking at pics, the procomp looks higher so I like it lol
Josh
Thanks for the input. That really helps make my decision.
Matt
Put an order in for the lift, tires, and wheels today. Hope it comes out the way I want it or I'll be pretty sad. Thanks for everyone's pics, comments, and inputs. They all played into my decision. Here is what I am getting:
Lift: 4.5" Zone lift
Wheels: 18x9 +0 Offset
Tires: 295/70/18 Nitto Trail Grapplers
Misc: .5" strut spacer (to help clear the tires) and 1.5" wheel spacers for the rear (so they match the poke in the front)
Again, thanks everyone. Pretty excited. now a week of waiting for everything to come in, then making the appointment at the shop.
Matt
So it's finally time for a suspension lift - the Supreme Suspension leveling kit I'm running is making the control arm hit the knuckle - hopefully that terminology is correct.
I currently have Mayhem Patriot wheels (-12 offset) and Falken Wild Peak A/T's in 305/55/r20. The tires stil have over 80% tread left (and weren't cheap @ $250 each). I'm going to go with the RCX crossmember lift. The shop near me does 5" -7" for the same price. It seems silly not to go with the 7", but I don't want my truck looking like a skateboard if the tires are too small.
Does anybody have a 6 or 7 inch lift with this size (or comparable) tire?
How the truck looks currently.
Matt
I look forward to seeing the outcome.
Matt
How come you are going with the 4.5 and a spacer instead of just going with the 6.5? I had a 4.5 inch on my last truck and I ended up adding a level and body lift to make it higher. Won't make that mistake again lol
it's only a .5" spacer, so it's a .25" thick. this is only as a precaution in case the tires won't fit up front. talked to a guy who has done some really nice trucks out in alabama and this is what he recommended. I didn't go with the 6.5" lift because it's too tall for my taste, and more importantly my lifestyle. I need to be under a certain to height to get into work and into my garage. That being said, if i need to, i can just get the upper strut spacer and rear block to make my lift a 6.5" from zone. so it's cool.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
