As promised. 7.5" RCX lift with Falken Wild Peak A/T 305/55r20. What I didn't anticipate was the front wheels sticking out further than the rear after the lift. I'm definitely going to have to get spacers to even it out. They're definitely too small, but will suffice temporarily.
Lol someone skipped leg day.
Sent from my SM-G900P using Tapatalk
If my body were a truck, after my workout yesterday I feel equivalent to a truck stuffed with huge tires. Something like this..
Here is my submission to this thread. Its my 2016 GMC All/Terrain 4x4 6.5" Zone with AAL, 35.4" Duratracs on stock 20" Denali wheels.
Edited by NEMESIS-A/T
  • Like 10
Your truck looks great! Do you have the 6.2?
Thanks man, Yes 6.2 with Tow package and 3.42 gears.
Got my lift and stuff ordered. Can't wait. Decided to go with the zone 6.5, 20x9 fuel mavericks, 35" Firestone destination MTs and 1.75" rear wheel spacers. Pumped
Sent from my E6853 using Tapatalk
Can't wait to see it finished!
Who's running a 4.5" zone with about 0 ish offset and 33" I wanna make sure I won't look like I'm 'skipping leg day'?
Thanks!
I'm gonna get 35x12.5r20 trail grapplers instead, they run big tho. My wheels will be +14 offset I'm hoping they won't rub!
Hello All,
I'm new to the Forum and looking to purchase some 22x12 -44 offset w/ (305/50/22) for my 2015 GMC Denali 2wd. What lift is needed that will allow no rubbing or cutting? I've serach through the forum and didn't find any thread similar to my set-up.. Thanks in advance. What lift kit is the best?
Edited by CLDenali
If the Trails weren't so dang expensive I would have run those too. They do have a cool as hell kinda look to em.
How do you like the 35s with the 3.42s? Any plans on regearing in the future?
I did have plans to do so, but after I did the install and had the alignment done. I paid close attention to its driving manners and I see no reason or signs of it struggling.
finally got my truck back -
4.5" zone lift, 18x9 +0, 295/70/18 Nitto Trail grapplers
I love it. extremely happy with the outcome. I MAY do an AAL as the rear seems to sit just below the front...but not sure yet.
Lifted
Lift getting finished up
Lifted - for comparison
lifted -2
  • Like 3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
