Those of you with the 7-8" Mcgaugheys, did you get the economy or the more expensive one?
Reason I ask is because I have the all terrain with teh skid plates already, dont want to spend the money for nothing!
here are the differences between each kit.
Economy- Adjustable 7-9" front struts, Simpler Front Drop Cross Members, Round Kicker braces, 6"Rear Lift blocks , No Diff Skid Plate & No Tie Braces between crossmembers
Standard- Adjustable 7-9" front struts, Traditional Front Drop Cross Members, Round Tubular Kicker Braces, 6" Lift Blocks
Black SS- Adjustable 7-9" front struts, Traditional Front Drop Cross Members W/ Stainless Steel Accents & Hardware, Box Fabricated Kicker Braces, 6" Lift Blocks
Hey guys, I've tried searching with little to no results. Just curious if anyone has the 4" BDS with 35x12.5 on 18s or 20s. Curious as to what it will look like...
On the BDS site it reads, for the 4" kit
  • Tire & Wheel Combinations
  • 33" x 12.50" w/17 x 9 and 5" back spacing
  • 33" x 12.50" w/18 x 9 and 5" back spacing
  • 35" x 12.50" w/20 x 9 and 5.75" back spacing
So my question is, why would an 18x9 with 5.75" back spacing work? Am I missing something?
The 4" kit is ordered, along with 18" mayhem warriors, tire size is still opthional but I priced out 35x12.5x18 KO2's.
Thanks in advance,
Thanks in advance,
I would assume the wheel might hit the control arm when turning. Might have to wait for someone with a kit to chime in. Or call BDS, I heard there support is great.
Damn I didn't think of it like that, with the actually inside diameter of the wheel coming into play...makes a lot more sense now.
But then again, how would that change tire diameter? It can fit an 18" wheel without rubbing any suspension parts, therefore the increase in tire diameter should have no effect?
Edited by tanner709
Got the new wheels installed today, 24X14 American Force 8 Spoke Burnouts with 37" Toyos, I also installed 2" lowering shackles too in the rear 954aca9f410403ec03d69993374fc02a.jpg7412747315a898cb47643ade64670660.jpg
Dude that looks freakin sick. I'm normally not a fan of trucks lifted that high but that looks good man.
I'm getting the BDS 4" kit with fox coilovers w/dsc and fox rears. I'm running custom factory 20's and 35x12.50 toyo rt's. I'm getting it out on this Friday so I'll post pics and let you know
looking forward to seeing this one
I'm new to this site and was hoping someone could help me out, I have a 2015 silverado I have a rough country 3.5 lift with 305 55 20s my wheels r kmc xd series I have posi 18 offset wish I would of gone neg, I'm gunna use hub centric wheel spacer I don't need to cut my studs becuase my wheels have the cut outs, so I'm thinkin of doing 1. 1.25, or 1.50 spacers anyone know wut I could fit without rubbing
Any body have trouble getting Camber in specs? What options are out there if so? Upper control arms? Camber kit bolts?
Guys with 8" or higher lifts.. has anyone come across a problem with maxed out camber? What options are out there for these trucks to correct camber?
I have taken pictures nearly every day this past week! haha! I get super excited to drive my truck, like a teenager who just got their first car. Here are more pictures. Shoot me a PM if you want a better side shot of the track width than what is below. I can take one tomorrow for you. I asked a dozen guys a dozen questions about their trucks when deciding what to do with mine and don't mind paying it forward!
Nate
Hey Nate
Did you upgrade to the Fox shocks?
Hey Nate
I did not. I originally wanted to and thought I would wait and see how it handles off road and how aggressively I am really going to drive this thing in dirt, sand, etc. One of the suppliers was running a very sweet group buy on here and the price was excellent (ended last Sunday). I almost pulled the trigger but opted to put the money in some car audio for now instead of coil overs. I am running the truck in some sand dunes this weekend, should give me an idea if I am happy with the stock coil-overs or not. I may eventually do the upgrade... you can jump these trucks pretty high off the ground with those fox coil-overs!! Something I am not comfortable doing until I pay this truck down! haha!!
I have these http://www.texastrucktire.com/uploads/4/4/9/1/44915107/s160087193180611566_p5_i1_w640.jpeg 20" stock. I see the 4.5 can squeezed the 35s with this setup. although this is not ideally what id like but I want to keep that stock look to see what it looks like. Does anyone have that setup 4.5 with 35s and stock 20s?
Also Nate, what shops did you recommend for Socal? I couldnt find where we had talked about that. Thanks again
I replied with info in a PM back when you sent me this... did you get my message? You decide on a setup and shop for your truck?
I can tell you what I did on my Pro Comp 4" lift. I had 17" factory rims and I had to use 1.25 spacers. When I ordered my X-Series Rockstar I had to order with -12mm offset and I got rid of the spacers.
Good Day All,
I have a 2015 Sierra All Terrain, I want to lift it 4" and run 33" tires. I'm looking for recommendations on tires and lifts. Ive been looking at BDS 4" and wondering if the full coil over suspension is worth the extra$$$ or if I would ride as good with the basic Spacers.
Good Day All,
Coilovers will ride better and give you adjustability to go a little higher if desired. If money wasn't a concern you'd be foolish not to run the coilovers
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,270 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
