So ever since I had lift n tires and gears done I've been needing to recal my speedo. Was off a lot. Finally got the balls to tune it with a Diablo Intune i2 yesterday. Did the 91 tune with corrected gear ratio, corrected tire size, firm shifts and DOD off. Took a ride today to a buddies house and this is what I am getting for mpg now. I was pleasantly surprised.
Solid 18 mpg combined highway/town.
Cruise on 70 = 18.1mpg
Cruise on 75 = 16.2mpg
Off highway back roads to his house... get this...over 19mpg!!
Tranny shifts way better. No V4 crap. All around better response and drive.
A7540F44-72D9-42FF-A5C8-1F0CDDC29271_zps
Ok so back on the 11th I posted this pic of my mpg's the day after I installed a canned Diablo tune.
Figured I'd update with a pic of my mpg's after 400 miles of all around driving. I am pleased and am planning a custom Diablew tune shortly. Maybe I can improve on mpg's a little more.
B27404C4-698F-4851-AFD7-A82FF54B1FC9_zps
Had some fun ripping my truck through the mountains this past weekend. Trails were in Big Bear, CA. 71705a273c5b5af17b93779f8f983f83.jpg
Pretty sweet! Looks like you had fun and beautiful truck. I will have to head up there when I get some free time and check it out. Haven't been in a couple years now.
Lift is finally done!
Zone Offroad 6.5" Lift
Fuel Renegade: 20x10 -19 Offset
Cooper Discoverer ST Maxx: 35 x 12.50
what do your fenders measure?? I forgot to ask
Sent from your sister's house
For anyone who was wondering about tire fitment with a 4" lift, here are a few pictures of my truck. I ended up going with a 4" Fabtech and 295/60R20 Nitto Trail Grapplers with stock wheels. Rides great and only slightly rubs the plastic wheel well and full lock. Hopes this helps anyone who was curious.
post-148779-0-75414600-1467676251_thumb.jpgpost-148779-0-04116100-1467676279_thumb.jpgpost-148779-0-31628400-1467676288_thumb.jpg
  • Like 8
did that lift measure out to be a true 4 inches? I got a level and a body lift totaling 3.75 inches in lift and was wanting a 295/60/20 but wasn't sure if it would rub bad..
I believe so, it's a 4" Fabtech I purchased from 4 wheel parts. I'd have to read deeper into the specs to find out the true lift measurements. I've had the kit and tires on for about 6 months now and don't have any complaints.
I can't figure out why all of these manufacturers that make these 4" SST type lifts always say "WILL NOT WORK WITH OEM WHEELS", then every lift I see in use has the factory wheels rolling right along.
Truck looks good!
Edited by aware
2016 Silverado
5" RCX Suspension Lift
33X12.5X20 Tires
20X9 Fuel Throttle Rims
Flowmaster 40 Series Muffler with Turndowns
ICI Magnum Steps Coming Tomorrow
Bracket lift or knuckle lift? Have more photos?
Looks great. I think Rough Country always leaves a little too much rake with their 5 inch kits whether it's the bracket or knuckle lift.
Thanks man. I think they should include a little bit of a smaller block for the rear, that would probably level it out. I decided to go with the spacer though. Didn't want to lose any height.
2016 Silverado 1500 Wt Midnight Edition
Camburg 2.5 Coilover Kit
285/70R17 BFG KO2 on Method "The Standard"
post-159851-146778134947_thumb.jpgpost-159851-14677813724_thumb.jpgpost-159851-146778138194_thumb.jpgpost-159851-146778140295_thumb.jpg
Sent from my SM-G930P using Tapatalk
i wish someone on here had a superlift 8" i want to hear the reviews...i cant fine much of any expecially on the 14+ platform
Just dropped my 2015 gmc sierra all terrain off to get lifted. I'm going with a 7-9 mcgaughys black ss lift set at 9 with an add-a-leaf as well as a 1.5 inch zone body lift. I also have a set of bushwacker fender flares and 4.56 yukon gears. For tires I am using 37x13.5r20 toyo open country m/ts and for rims I am using 20x12 fuel assaults with a -44mm offset. As well a cat back borla atak exhaust. I am beyond excited. Pictures will come when I pick it up!!!
Truck looks good!
Usually these with oem rims are running a wheel spacer in order to clear spindle or upper arm as when lifting your tires come in naturally so to offset and act like an aftermarket wheel they run spacers to clear
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
