17 minutes ago, TXGREEK said:
Good question emoji848.png but I’m sure there is some sort of bypass just for the rods of the Magnetic ride. I’d call them end of the week
Can’t by pass the magnaride, all wired into the system. Light will go off like a Christmas tree! Stuck like chuck with it. It’s cool Fabtech kit working fine
I have the 8 speed trans. How is the horse power after the tune? Can you set it to compensate for the 35’s?
Absolutely. Obvious noticeable increase in Torque and HP. You can do anything with it even turn off the AFM as well as turn off the speed limiter too. Awesome device.
I meant doing the CST and use another little setup for the magnetic ride.
I see they have a few different devices, which one do you recommend? Are you able to change computer for tire size?
F5, yes you can adjust for tire size. Go online and check it out, very sweet device. I keep mine in its case locked up in the truck. Pull over right before getting to dealership and then do warranty work or servicing.
Just so you're aware, your truck keeps a flash count on the ECM. So if a dealer really wanted to, they could pull that number and see you've had a tune, regardless of the fact that you flash it back to stock before the service. Likely won't ever be an issue, but just so everyone is informed of all variables involved
Good to know, hasn’t happened yet. Besides, it’s got to be proved that you didn’t just program for larger tires. Don’t want to get into a discussion about it and go off topic.
Agreed, just wanted to make sure people knew about that or know that if they read these posts as research! Carry on with more lifted trucks [emoji2]
You are correct sir.. Not many people know about it...
Bottom line is if you have a major engine or transmission failure, you will be paying for it.
Sent from my SM-G965U using Tapatalk
I researched trying to get rid of the magnaride but was told it’s part of the electronics for the suspension system. I had to buy 2 new front struts & they set me back $700! Would rather had bought a set of off road shocks! I don’t think they meant for Denali to really go off-roading
I know of it, never had any issues with a can tune. Besides, aside of this discussion going off path, I’ve got a great relationship with my service dealerships and it’s got to be proven that what you’ve done is what has caused your issues, SuperChips even gives a great warranty as well in the event your stuck with the bill. So many already existing issues as it is.
How many people lift their truck because they are going offroad?
How many want to lift their trucks so they can go off-road without having limitations that would otherwise damage their trucks under chassis components?
It's not up to the dealer.. Any major engine or transmission work requires cals sent to the General before the repairs..
Unless the dealer is willing to eat it.
    erickn520
    erickn520
  • Who's Online   4 Members, 0 Anonymous, 1,717 Guests (See full list)
