Finally got around to putting on the Zone 6.5" lift on the 2014 LTZ. Had to install a Add-a-Leaf in the rear to get it to sit level. Running 35 x 11.5 Ridge Grapplers on stock wheels. 1.5" spacers in the rear to match the front poke. Very happy with the results.
I’m looking to put an add-a-leaf on my 2017 LT Z71 but I’m concerned it will make the rear too stiff. Are you happy with the rear suspension with the extra leaf?
I have 2018 HC 1500 2wd
and did a MaXtrac 5inch spindle lift
with Fox 2.0 coilovers and rear shocks
the shop lower the coilovers a inch to
even out the back
the ride Quality is really bad
i can feel ever crack on the road get Worse a high speed’s
only have 7k miles on my truck
any of you had this problem before
i when back to the shop where I got them  installed they told me
I need to drive my truck 3k miles to break them in
even out the back
Have you owned a truck before? Also what size wheel and tire? Also do you mean they raised/put more tension on you coil overs because you rear normally sits at a higher rake so the would have to raise them to level the truck which would definitely stiffen up the ride.
I believe rake is important if you tow.  Leveled trucks look cool too.  5" is a hefty lift so it's not surprising it feels stiff.  You also have tall rims.  Looks like 20" or 22".  not much rubber to give cushion there.  Good for street cornering though.
Also I haven’t seen a lot of fox coilovers on 2wd’s.. that’s a lot of suspension with a couple hundred lbs less weight up front which could also be adding to rough ride.
Yeah this the first truck I own,
the tire setup
305/55/20 toyo AT
 I had a 2.5 leveling kit with the same rims and tire and the truck run smooth
i decided to get a bigger lift
now the ride sucks
t
with the spindle 5in + 2in from coilovers would be at 7inch
i had them lower a inch so it would at 6inch So I could run the tire already had
i
That looks really good, makes me want to run my stock LTZ wheels on mine.
even out the back
I have the same set up on mine with 35's on 22's. while the ride isn't as smooth as stock I really don't think it's bad.
Are those the compression forged wheels? I like those.
Yes sir they are, I like them. I switched to those a few months back, I originally had a set of American Truxx
Nice looks good both ways
Thanks, I really rather the AXE wheels on it. My intentions when I bought a truck was to get a white one and do black wheels but the dealership didn't have a white one at that moment and I good one of those last day of the month closing time deals so I settled with silver
Yes, I'm very happy with the ride after the add-a-leaf. I was expecting  a stiff/harsh ride, but it's amazingly compliant. Not much different than stock, except I can feel the rumble from the tire tread at low speeds(10-20mph). Looking forward to the add-a-leaf when towing the Camper(6000lbs).
I think that’s what took the most getting used to for myself my friend was the feeling of the tread vibrations at low speeds. It was like you can feel each nub grip the road haha
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
