2 hours ago, arkenzo said:
Are any of you guys upgrading the upper control arms with your lifts ? Low priority or just don’t need them?
I would if I was doing any of the stretched out levels.  I think some even come with arms.
Is there would be absolutely no benefit to getting upper control arms with suspension lifts ? Unless your balljoints go bad I suppose.
Anyone have pictures of CV angles of the zone 6.5” kit? I had a 4.5, but looking to go up this time around I think.
Old truck that was totaled out. Zone 4.5, Bora 1.5” rear spacers, 20x9 0 offset XD820, 305/55/20 falken at3w. Zero rub, zero issues. Well, except for being tboned on my way to work.
22860d51bd75f180341f2a241c9912d7.jpgthats the Zone 4.5” set at 5.75” with the 5100s. Another 3/4” would be fine
That’s perfect. I remember my 4.5 being perfect but wasn’t sure how bad the 6.5 would be. I thought about modifying the strut spacers to 5.5” so it’s a happy medium between the 2, because I only want to run a 33, not a 35. Been there done that on a 1500, no thanks!
If you want an in-between to the 4.5 - 6.5 just do the 5100s, then you can run it at 4.5 , 5.25 , 5.75 , or 6.35
Those angles look good.  I'm getting Zone 4.5 tomorrow, installer said later I could get 5100s or some people slide in a small spacer to level up lift.  That truck look great.
Thanks!
Finally got a decent day to clean up the truck a little bit. Here's my 4.5" Zone with 33x12.50x20 Toyo R/T and Hostile Sprockets.
Pretty happy with how it turned out. I will be ordering 35x12.50x20 Toyo A/T2 Extremes and Fuel Blitz wheels as a summer setup.
20x9 sprockets?
2 minutes ago, Criscone said:
What offset? Looks like + something?
I want to say +10.
Edit: for sure +10, I just checked out the specs on Hostile's site.
Edited by buckeye6
CST 4 1/2" Bracket lift, 20x9 Hostile Rages, 285/60/20 Toyo RT's. Will be going 20x10 when this Winter is done. Also adding a Deaver Mini-pack to the rear to replace the CST 3" block.
First time posting, 2015 GMC Sierra SLT 14k Miles
22x14 -76 American Truxx wheels
325/50/22 Nitto tires
McGaughys 9” lift with add a leaf set at 9.
2.5” Bora Spacers in the back.
  • Like 5
Love it man how high does your truck sit to the point of the roof antenna?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
